Industrial robot for X-sim use ??
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Princemester, Jul 22, 2011.
  1. Princemester
    Princemester New Member
    Robotic Engineer
    Hertfordshire UK
    373Coins
    Hi , ive been looking around the forum and am loving all the sims that are being made . I was wondering if you could use X-sim with an industrial 6-axis robot . I work for a second hand robot dealer and have access to pretty much all robots on the market now and the past 20 years , as my background is ABB i would probably use one of these.
    What i'm struggling to find is the way to get the force info from the game and in what format would it be . The robots have pretty much any comms protocol such as serial (RS232) or ethernet . Am i right in thinking X-sim can output a string over serial from the pc comm port ? if so i could interpret this data in the robot and translate to a movement .
    I hope someone technical could answer this question ? :sos:
  2. RaceRay
    23,864Coins
    It´s easy to send serial strings to the roboter arms when the are controlled by simple ASCII control characters, but it needs a lot of efforts to make a usable AND lifesafe profile as a robotic arm got a lot of axes which can be controlled independently from eachother. Without a hardware mechanical safety and movement limiting implementation i repeat the answer of sirnoname:
    Do not do this!!! You can try it for testing and developing issues, but never get your body in that thing!
  3. RaceRay
    23,864Coins
    Time to clarify such things in the user license agreements i think!
  4. Princemester
    Robotic Engineer
    Hertfordshire UK
    373Coins
    OK , i understand what you are saying . Thanks .
