Input and Output Interfaces
Discussion in 'Force-Profiler Simulator Control' started by tpba, Sep 15, 2009.
  1. tpba
    tpba Member
    IT
    Melbourne, Australia
    374Coins
    Hello
    The input and output boards that I am currently writing my DLL for are actually separate model boards... Should I code them as separate modules or is it safe to do them together...?
    I guess for the sake of code re-use each one should be a separate DLL ?
    t
  2. tpba
    tpba Member
    IT
    374Coins
    I don't believe they function as a single comport - I believe they are separate... Actually, I don't believe they are even classed as a commport, but I need to dig deeper into the existing code to verify.
    T
  3. tpba
    tpba Member
    IT
    374Coins
    Hi again ( and hopefully sirnoname )
    I'm going through the 10BitUSB interface source code to adapt it to my own hardware.
    Can I please ask a few questions ( sorry but they're not in programmatic order ) just to confirm my understanding...
    * It seems that the input data is read via the method ContinuousReadThread ?
    * It also seems the output data is written via the SetValue method..? Not sure if I missed somehting there..
    * I notice the function ReadOutPacket contains a writefile function - so is this a read or write function ? perhaps it is not named correctly ?
    * Lastly, the GetInputs seems to list the inputs numerically for the calling program right ? How does the calling program access the output numbers ? i know they get setup in one of the functions, but I can't see how the calling prog knows which outputs to write to..?
    Tim
  4. tpba
    tpba Member
    IT
    374Coins
    Thanks Martin
    Do you mind if I get you to check my understanding please ?
    This leaves me puzzled then.. I've checked here - http://www.x-simulator.de/wiki/Writing_ ... ofiler_2.x
    This list doesn't tell me which method is the read input from device method :
    •DllInfo GetType(void);
    •IOsharing GetInterfaceIO(void);
    •INPUTSTRUCT GetInput(bool inputs[255]);
    •int ExecuteVirtual(void);
    •int SetOutput(int number, unsigned int wert);
    •int IsConnected(void);
    •int SetVirtualOutput(int number, unsigned int wert);
    •void InitDLL(void);
    •void EnableThread(bool enable);
    •void OpenSettingsDialog(void);
    The descriptions in the manual don't seem to talk about the actual reading function.. I was expecting to see the profiler call the read method which would run in it's own thread - is that assumption wrong ? I think I'm missing something - sorry in advance.
  5. tpba
    tpba Member
    IT
    374Coins
    Ahhhh !!! The penny drops. Thanks for clarifying that...
    Now, onto the output side of things... Just to be sure - I should use the virtual set function for outputting my motion control commands ?
    t
  6. domotto
    domotto New Member
    GINOSA (TARANTO) ITALIA
    - 210Coins
    DC motor, JRK, 4DOF
    hello please help me I can not set output k8055 setup pneumatic solenoids could you tell me what values to set or maybe a setup shema aiutatemi.grazie please, I am new with x-sim. :sos:
