Interface Sample Source
Discussion in 'DIY Motion Simulator Projects' started by stowaway, Jan 31, 2012.
  1. stowaway
    stowaway New Member
    Gold Coast - Australia
    1Coins
    I have been going around and around in circles, But I can not find the interface sample source that it says here:
    You will find two sample source codes. One is based on the velleman serial output to a K8063 interface and one is a input to a ADC USB interface which also use serial comunication. (USB to RS232 adapter onchip)
    http://www.x-simulator.de/wiki/Writing_ ... ofiler_2.x
    Is there any Sample Source I can look at?
  2. stowaway
    stowaway New Member
    1Coins
    ahh, I had it all along :) C:\Program Files (x86)\X-Sim\other stuff\Sourcecode\InterfacePlugin
  3. stowaway
    stowaway New Member
    1Coins
    Hi Sirnoname, What do you mean interface plugins have a bigger support in the software itself?
  4. stowaway
    stowaway New Member
    1Coins
    excuse my ignorance, as im just an amateur C# and java programmer with a course of C under my belt (not c++)..
    but how does one debug the interfaces? Im going over it line by line but I would like to do it in the debugger... But I cant run-debug a dll...
  5. stowaway
    stowaway New Member
    1Coins
    Im still playing with the interface source. Ive found a round about way to debug by just putting MessageBox's everywhere when i want to know the value of something and running the program..
    But im wondering, Is there any benifts to building my own interface as opposied to the USO?
    the reason i ask is someone has squashed my dreams of creating my own chip (im working on 2 solutions.. 1 involves using tronics design and 1 attempting my own).. But im told the Arduinos are too slow to run it smoothly (it would suck going over this line by line only to discover my hardware isnt up to scratch)?
  6. stowaway
    stowaway New Member
    1Coins
    So, is this what you are suggestng..
    The Ardunio will give Xsim the position of the pot xsim will tell ardunini move AxisX,Y until axis's are in the right spot and then tell it to stop (instead of telling ardunio the position it needs to be in and the arduino moving motors and stopping motors when in the correct position)
    is that what your saying?
  7. stowaway
    stowaway New Member
    1Coins
    great :)
    thats a good start. thanks.
  8. stowaway
    stowaway New Member
    1Coins
    I took this psydo code for the PID from http://www.arduino.cc/cgi-bin/yabb2/YaB ... 1250907652
    So, what I am workign wiht now, Is X-Sim gives me a Position where it wants Axis-x and axis-y. It has the current position of axis-x and axis-y that the ardinuo will supply it from its POTs.
    So it sends the Arduino the Proportional (error) value and the arduino will use the below formula to try and correct itself so its error is as close to 0 as possible (2 DOF 2 PID's)
    (Please let me know if im way off base)
    ...would i be just better off giving the arduino the axis-x and axis-y positions and not hte PID value.. and it can calualtor the P (error) value and correct from there..
    //stolen PID FORMULA that the arduino will do
    sensorValue = getSensor();
    previousError = error; //store the previous error
    error = sensorValue - actuatorValue; //this is how far we are from our goal
    integralPart = integralPart + error; //this is the integral part which eliminates the steady state error
    if(integralPart > antiWindUpLimit) then //here we limit the integral part
    integralPart = AntiWindUpLimit;
    if(integralPart < antiWindUpLimit) then
    integralPart = -AntiWindUpLimit;
    //this is the PID calculation
    actuatorValue = pGain*(error + dGain*(error - previousError) + iGain*integralPart);
    //this can also be written like this
    actuatorValue = pGain*error + dGain*(error - previousError) + iGain*integralPart;
    //just expanding the multiplication to understand how the change of each gain affects our system better.
    setActuator(actuatorValue);
  9. stowaway
    stowaway New Member
    1Coins
    I will have to do some more research on the theory...
    I thought hte PID was the value of the error from where something is and where it needs to be.
    I dont understand why it would only be sent once at the start and not continually through the game.
  10. stowaway
    stowaway New Member
    1Coins
  11. stowaway
    stowaway New Member
    1Coins
    So Just so im clear in my theory.
    the P - I and D values are set at the start of each game to fine tune the the speed the motors find the correct position.
    Why isnt it possible to find out values are best to get the simulator to the correct posistion and use it for every game? Why would the PID be different for different games?
  12. eaorobbie
    20,440Coins
    ya proberly know this already the arduino has its own pid libary even explains how us adaptive pid tuning allowing code to adjus pid values when too big of an error occurs. This is where i went over me head still trying to surface.
  13. stowaway
    stowaway New Member
    1Coins
    yeah ive noticed it has a PIDlibrary...
    im a complete n00b to Andrino. (and MCU etc)
    but i thought i would design it myself rather than use library,, I didnt evne look at the library I was thikning about efficience and only including exactly what i needed for my project..
    anyway I beleive I have the theory in my head. Next step is putting it into pratice with a model sized simulator
  14. eaorobbie
    20,440Coins
    cool i will try and find time to vid what i have done plus post the code to it, just been real busy with work life.
  15. eaorobbie
    20,440Coins
    ok the hbridge i was testing with the arduino is from spark fun - Monster Moto Shield.
    Its a good alternative if i can get the pid of the code right.
    http://www.sparkfun.com/products/10182
    You have to wire in two pots for feedback but it is equivilant in power output as the jrks from pololu.
    It runs two of the same motor driver chips so ya get 2 for one.
