Question Interface Settings minimum Output-Bit Range for Odrive
Discussion in 'SimTools DIY Version' started by Icebeat, Nov 4, 2020.
  1. Icebeat
    Icebeat New Member Gold Contributor
    - 61Coins
    In the current version of Interface Settings Serial, the available bit range are from 7 to 32, this is incompatible with the new Odrive firmware.
    Any possibility to not use bit range at all? a better option will be to map axis ranges to user-defined values Min and Max?
    147,878Coins
    +10,880 / 54 / -2
    One for @yobuddy to consider.
  3. yobuddy
    49,198Coins
    We could build an ODrive interface easy enough.
    What output range does it need?
    Take care,
  4. Icebeat
    - 61Coins
    I already build my own 3 minutes version using your serial plugin, thanks for sharing ;)
    As you can see my min-max values are -5..5 but other users can desire different values dependent on actuator length, ideally the interface should have two edit boxes with min and max values.
    GetOutPut (...
    Dim slope As Double = 0
    Dim output_start As Double = -5
    Dim output_end As Double = 5
    Dim input_start As Double = -1
    Dim input_end As Double = 1
    'Bits
    Select Case BitsNeeded
    Case "0"
    'Out the value
    slope = (output_end - output_start) / (input_end - input_start)
    OutPut = output_start + slope * (InputPercent - input_start)
    'Odrive uses float
    'Convert to an integer
    OutPut = Math.Round(OutPut, 3)
    Thanks,
    sorry for my VB.
    icebeat.
  5. yobuddy
    49,198Coins
    But most users would not know what 8 or 16 bit min max numbers should be.
    So maybe another version with editable settings would be best.
  6. CNCModeller
    CNCModeller
    Hi @yobuddy ,
    I'm new here and hoping to use ODrive for my build, so sorry of this is something I should know already.
    Is there a arduino based solution that'd allow me to connect to my ODrive over CAN bus so I can make my build easily expandable?
    I'm using ODrive for my DD wheel, and am very impressed so wanted to use is for my motion build too. Seems to me that almost everything I need w.r.t closed loop control of a Brushless motor is built into ODrive already, just need a way to communicate.
    https://www.xsimulator.net/community/threads/another-dd-hoverboard-motor-sim-wheel.15628/
    Any pointers would be much appreciated.
    All the best,
    Barry M
  7. CNCModeller
    CNCModeller
  8. yobuddy
    49,198Coins
