Introducing the Symdeck speed fans
Discussion in 'Commercial Simulators and Peripherie' started by levers, Feb 29, 2020.
  1. levers
    levers Active Member Gold Contributor
    955Coins
    Hi fellow sim racers.
    We'd like to introduce to you a product which although is quite simple can add a lot to the immersion of sim racing. Our speed fans give you the impression of speed on either a static or motion sim as they vary in force depending on the speed of the car being driven.
    They comprise of 2 fans which come supplied with double sided foam pads and cable ties and a control unit. Simply mount the fans, plug them into the control unit, plug that into the mains and connect it to the PC via the USB cable.
    Operation is driven by the Game Dash software and we can provide profiles if necessary.
    You can find them and other products on our web site.
    https://symdeck.com/fans/
    Thanks,
    Levers
      File size:
      541.5 KB
      309
  2. RacingMat
    20,962Coins
    would you mind sharing some specs about the fans:
    cfm?
    noise level? there is only a gif on your website, no video
  3. levers
    955Coins
    Hi RacingMat,
    Unfortunately I don't have the flow rate but they are rated at <45dB. With the 2 of them at full speed I'm glad I were glasses! Any more and it would start to distract from your driving. I'll see if I can add a video clip with sound to the web page but you won't hear them over the car noise so I will shoot a new clip with the game sound off.
    Regards,
    Levers
  4. levers
    955Coins
    Sorry for the delay, I've added a short video showing the fans at full speed with audio so you can here how quiet they are.
    The streamers are only to show the power of them!
