iRacing Launch
Discussion in 'iRacing' started by djl94, May 10, 2025.
  1. djl94
    djl94 New Member Gold Contributor
    72Coins
    Motion platform
    I'm having a problem where if I launch iRacing from SimTools V3 I have no motion but if I launch iRacing separately, get in a race and then hit the play button in SimTools, motion works fine. If I try to activate motion even in the iRacing UI once I get to the race it will not work. Motion will only work if it’s turned on in the pit once the race starts
    I’m running the game through Steam, the SimTools short cut is already set up to iRacing
    I want to make it where I can launch the game through SimTools without having to do all of these extra steps
    any suggestions?
    thanks!
  2. Radje748
    Radje748 Member
    275Coins
    Maybe a silly question, but you are sure that Autostart is on in SimTools ?
    I am also using Iracing, but not via steam...(and to be honest...Iracing is better via its own launcher).... I had all other strange issues when using Iracing Via steam(stutter, FFB acts odd)...
  3. Misanthrop
    Misanthrop Active Member
    754Coins
    I think Steam is the problem, there is no need to use it with Steam.
  4. xFFBx Tearier
    xFFBx Tearier ffb Tearier Gold Contributor
    208Coins
    I’m having a similar issue. Did you ever fix this
