Japenese SNC5 coexistance with SNC5 with positive ilk
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by abs, Jan 5, 2017.
  1. abs
    consultant
    Montreal
    784Coins
    3DOF, SCN5
    I want to add a Japenese SNC5 with negative ilk to my setup that has already 2 SNC5 with postive ilk. It seems yo me that it is not a an issue as long as there is 2 different circuit / can you confirm ?
    the only down side is the need of two emergency stops?
    thanks
  2. yobuddy
    49,509Coins
    @abs, I bet you could use a relay to solve this with one emergency stop.
    Or easier yet, is to use a switch that is a double pull double throw.
    (so it basically controls the 2 separate circuits with one switch.)
  3. abs
    consultant
    Montreal
    784Coins
    3DOF, SCN5
    thanks a lot yobuddy taking the time for the confirmation
    I did not take a chance and ordered from frex a snc5 with euro ilk (+24v). That easier as all the wiring is already there , I am swapping a 100 mm stoke with 150 mm stroke in my traction loss 3 rd motor.
    I presume these japenese snc5 with + ilk are the exact same as the one from mirai
  4. Historiker
    Michigan USA
    9,201Coins
    Moved to the correct forum section
