joyrider balance
Discussion in 'SimTools compatible interfaces' started by tetesim, Apr 12, 2009.
  1. tetesim
    tetesim New Member
    Hi Thano
    I have finished the joyrider : all function finally ; I test it with rfactor and it is very funny, But I have a problem of balance : I have difficut to find a point where the structure is fixed, motionless. when I play with rfactor there's a movement that don't produce the x-sim, but cause the instability of the system. How can I improve the stability ? I use ky = 6 and kx = 6; but i don't thing that the constants concern this problem.
    regards Stefano
  2. tronicgr
    tronicgr
    Hi Stefano,
    Some photos of your simulator and video of the strange behavior you mention will help more to understand what happens. Also post your Profiler .rnr file to see what effects you are using.
    I used X-axis KP4 and Y-axis KP6 on my joyrider cockpit to make it more stable...!
    Regards, Thanos
