k8055
Discussion in 'SimTools compatible interfaces' started by john01, Jan 15, 2013.
  1. john01
    john01 New Member
    is there a fix when i use two k8055 on one pc i get bad lag on second board
  2. bsft
    yes...buy 2 jrks instead for motor control, use the K8055 for dashboards :cheers:
  3. value1
    14,995Coins
  4. john01
    john01 New Member
    thanks for that but my chair works fine with 3 computers wish to go for two for quick and simple starup chair is 4pos. k8055 is great for my setup
  5. bsft
    It would be interesting to see your set up.
    Otherwise , if you ask the question on www.x-sim.de , there may be an answer there. :)
  6. john01
    john01 New Member
    thanks for that. Been to x-sim.de still new to posting. The site is to hard to workout into hardware not webpagers. I will post all my hardware info when i get the time been working on it 3.5 years now close to end game with this ver #4
  7. bigtalltim
    bigtalltim New Member
    Belfast
    361Coins
    K8055s work fine with electric motors - since sirnoname posted that comment about k8055s only being good for pneumatic or hydraulic I have done much experimentation, and fully documented a couple of viable k8055 solutions.
    http://www.x-simulator.de/forum/k8055-dual-wiper-motor-control-with-variable-speed-t2795.html
    Ok - not as fast as some of the commercial solutions on here, but super cheap and perfectly effective for aircraft sims
    Here's one of my test actuators:
    http://m.youtube.com/watch?v=if0nzgkNcgk
    To directly answer your first question, use a pc per k8055 - known issue ;o)
    T
  8. eaorobbie
    20,473Coins
    I would advise too only use it in a flight sim situation as its refresh rate causes way too much lag, pc end and game end to be an effective race sim, tested this myself many moons ago.
    No there is not a fix, makers wont update the dll for it. Sorry we have asked this from them.
