LCD readout on my motion contoller won't work.....
Discussion in 'DIY Motion Simulator Projects' started by jsmith2307, Jan 19, 2012.
  1. jsmith2307
    jsmith2307 Member
    Respiratory Therapist
    Corpus Christi, Texas
    324Coins
    2DOF, DC motor, Arduino, Joyrider, Motion platform
    Greetings!
    I built a Motion Controller v1.5 and now a problem with the LCD readout. I can't get the darn thing to work. The 2 LED on the board lite up when I power it up....but nothing happens on the readout,
    not even the square dots across the readout. The LCD is from MOUSER made by LUMEX # LCM-s01602DSF/I-Y is it correct? Also the backlight is 5.5 volts not the 12 volts DC from the PSU described in the LCD pinout page, (I found that out the hard way). The VCC on board is 5 volts, I can't get RS,E,DB4-DB7. It is not my PCB board, it was made by Sunstone. Can you tell me if what the other folks are using? PLEASE Help!!!
  2. eaorobbie
    20,440Coins
    dip switch for lcd set on, just a stab in the dark.
  3. jsmith2307
    jsmith2307 Member
    324Coins
    No, the dip switch is not the problem. I must have bought something other than HD44780. I found one at 411 Technology Systems. We'll see when it gets here in about a week. Later!
  4. jsmith2307
    jsmith2307 Member
    324Coins
    Again, no joy! I purchased a HD44780 from 411 Technology Systems and no luck!
  5. yobuddy
    49,490Coins
    We may be able to help you more if you can post pictures of your AMC + LCD, front and back please. :hi:
