Limit axis movement
Discussion in 'SimTools DIY Version' started by kalarius, Mar 9, 2014.
  1. kalarius
    kalarius New Member
    8Coins
    hi,
    How can I make the axis 1 and axis2 to move in the space from 0 to -40 and 0 to 100%
    I do not want to move more than -40 It is the stop of the axis.
    At positiove position I can move from 0 to 100%
    I want to limit the negative position
  2. eaorobbie
    20,431Coins
    not possible , the limits will take a even amount from top to bottom, limits over the centre.
    If using Ard this might be achievable in changing code.
    Maybe another way around this is to increase the -ve in the Tuning centres to which will lessen the negative movements too. I do this with the surge as I want more Accel movement and less braking movement with seat mover configuration.
