Linear actuator motion rig question
Discussion in 'DIY Motion Simulator Projects' started by frnotovii, Mar 14, 2023.
  1. frnotovii
    frnotovii New Member
    21Coins
    So I want to build a motion simulator with 4 linear actuators but I have a few problems stopping me and I need help. So first of all I need an actuator thats both high speed but also high weight lift and I dont know where to look and find one. The second problem is if I get the actuators then how do I connect them so that I can use them with sim tools. I dont know if i need an arduino and if i do then how do i wire everything up? Can someone please help my find out what actuator i need to use and how to wire it up to sim tools?
  2. frnotovii
    21Coins
    Also I want to stay under 225,76 dollars but my max is 270,91
    150,061Coins
    +10,993 / 54 / -2
    While slightly more expensive than DC rotary options, when it comes to both speed and load capacity I would suggest AASD15 servo powered actuators, with an appropriate controller they can almost be plug and play:
    https://www.xsimulator.net/community/faq/motion4sim-6dof-aasd15-servo-motion-controller.392/
    https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
    You can DIY actuators, which will be time consuming but cheapest option, use the Google Enhanced search on the Recent page to find the most recent related projects: https://www.xsimulator.net/community/find-new/posts?recent=1
    You can buy actuators, there are a range of options: https://www.thanos-motion.com/links-and-vendors/
    Budget depends on a whole range of choices and circumstances, so something you have to research depending on your own choices, priorities, skills and geographical location.
  4. frnotovii
    21Coins
    Thank you so much, this really helped me out and if I need anything else i will just post a reply here but seriously thank you so much this community is awesome!
