Live4Speed Orientation und Acceleration Fahrzeugbezogen
Discussion in 'Miscellaneous' started by HenriCarine, Jul 25, 2008.
  1. HenriCarine
    HenriCarine New Member
    France, Alsace
    396Coins
    Hi, thank's for these informations but where do you find them ???
    I use Live4Speed (S2-Z), drive with a Logitech Momo but under Yoda or Remote Yoda I only have IMagnitude who change....
    I tried too with my Sidewinder ForceFeedBack 2, with it I have IMagnitude and rglDirection who change, but still nothing else :sos:
    On my computer were running LFS, Yoda and Force Sender, on the computer of my wife there was Remote Yoda and Force Profiler but I certainly missed something in the configuration.....
    When my SideWinder is in use :
    When the Momo is in use :
    [Out Of Subject ON]
    I'm french, nice to discover this community, and trying to learn how to realise a Motion Simulator DIY. Sorry, I don't speak German (or more badly than a spanish cow :blush: ).
    I like Live4Speed and Iliouchine2, I have a trackIR3, dreams about a TripleHead2Go and a motion simulator 3 x 360°..... 8)
    [Out Of Subject OFF]
  2. mboRacing
    mboRacing Member Gold Contributor
    Automatiker
    Switzerland -Eiken
    - 151Coins
    Salut HenriCarine
    Tu va pas cherchez les Date's dans Yoda. Tu prend seulmont le Force-Sender et en category Physik-Plugin tu prend Live4Speed.
    Et voilat tu voit le date's dans le profiler (places 21-40, telemetric plugin)
    Salutations
    mboRacing
  3. HenriCarine
    France, Alsace
    396Coins
    Effectively, I deepened the problem in the afternoon and I discovered the utility of Force Sender, but I have a problem during the launch of LiveForSpeed, I have this window :
    I have the good location for LFS.exe, and the directory is not Read Only.
    Effectivement, je me suis repenché dessus cette après-midi et j'ai découvert l'utilité de Force Sender, mais j'ai un problème lors du lancement de LiveForSpeed, j'ai cette fenêtre :
    J'ai pourtant le bon chemin vers LFS.exe, et le répertoire n'est pas en Lecture Seule.
  4. mboRacing
    Automatiker
    Switzerland -Eiken
    - 151Coins
    Et si tu n'as pas ouvert le Force Sender, tu a cette problem quand meme?
  5. HenriCarine
    France, Alsace
    396Coins
    I have the error message if I press on Play Game of Force Sender. If I launch the game directly that works correctly.
    J'ai le message d'erreur si j'appuie sur Play Game du Force Sender. Si je lance le jeu directement tout se passe correctement.
  6. mboRacing
    Automatiker
    Switzerland -Eiken
    - 151Coins
    Alors, tu lance le force sender, et apres tu lance le jeux directement. Le force sender detect le jeux quand meme.
    c'est pas important que tu lance le jeux avec le button dans le sender...
  7. tronicgr
    tronicgr
    Yes, its a known bug. Don't use Play Game button!!! Use the Send Data button, and you will see the values of the LFS changing in the profiler (if you use second monitor)
    The proper procedure is:
    Load the LFS, minimize it, start Force Sender and press Send Data. Then load Profiler and press Start to get the motors moving!
    PS. what is this motion simulator 3 x 360° ??? Do you have any photos or links?
    Regards, Thanos
  8. egoexpress
    Allô Henri,
    T'as modificé le fichier (cfg.txt) dans le doisser du LFS?
    Ici les modifications qui tu devois faire.
    Conn To Master 1
    OutSim Mode 1
    OutSim Delay 1
    OutSim IP 127.0.0.1
    OutSim Port 4123
    OutSim ID 0
    OutGauge Mode 1
    OutGauge Delay 1
    OutGauge IP 127.0.0.1
    OutGauge Port 4124
    OutGauge ID 0
    Tu les peux trouver en bas de le fichier.
    @mbo
    J'ai savoit pas que tu parles francais :thbup:
    Salut
    Christian
  9. egoexpress
    Some kind of Gyrosim perhaps. In the end its just a dream, I think ;D
    Regards
    Christian
  10. mboRacing
    Automatiker
    Switzerland -Eiken
    - 151Coins
    @egoexpress
    mais oui, en suisse en apprend ca dans l'ecole 8) mais en verité c'est pour le sport automobile, les rallyes en suisse existe
    seulmont dans la pey de la suisse romande...
    :clap: aber ich staune auch über deine franz kenntnisse :cheers:
    Mais pourqui est le port 4124 outGauge? ce sont les dates de les gauges?? (et le port outsim pour les accelerations?)
    Salutations, Martin
  11. egoexpress
    Je ne sais pas, mais il marche :)
  12. HenriCarine
    France, Alsace
    396Coins
    Thanks to all for your answers and your help, I manage to get back the information on the computer of my wife, I see all the parameters correctly.
    About the motion simulator 3 x 360°, it's only an idea to make a seat capable of moving on 360 ° in roll, yaw and pitch..... fasten your seatbelt otherwise headache inside :clap:
    Something like that (I know, it's crazy :eek: ) :
    Merci à tous pour vos réponses et votre aide, j'arrive à récupérer les informations sur le PC de ma femme, je vois tous les paramètres correctement.
    A propos du simulateur de mouvement 3 x 360°, c'est seulement une idée de faire un siège capable de bouger sur 360° en roulis, tangage et lacet..... attachez votre harnais sinon mal de tête assuré :clap:
  13. tronicgr
    tronicgr
    Nice graphics! I really enjoyed the model inside the frames... :rofl:
    Anyway, it reminds me the Sega360!!
    Thanos
  14. egoexpress
    Lawnmover-Man :D
    Je trouve cette solution meilleure...
    gyrosim-t687.html
    salut
    Christian
  15. HenriCarine
    France, Alsace
    396Coins
    It is not the same design but the principle is the same, the goal too : vomit before half an hour :lol:
    Ce n'est pas le même design mais le principe est le même, le but aussi : vomir au bout d'une demi heure :lol:
