Login in Opera browser.
Discussion in 'Suggestions for improvements - Oudated' started by mrpio, Mar 24, 2009.
  1. mrpio
    mrpio New Member
    Hello Admins et al.!
    I don't know if it is something on my side, or has there been a script change recently? When I log in in Opera these days, I am logged out of X-Sim as soon as I'm redirected after login. Thus, I cannot make any posts under Opera at all! I used to have no such problem until recently.
    Logging works fine under IE, whose guts I obviously hate, and FF is also a last resort for me.
    Just FYI, really.
    Thanks again for your great work.
    Piotr
  2. RaceRay
    23,862Coins
    Hi Piotr,
    i tested the forum with opera. Everything is working fine. Doesn´t matter if i deactivate javaScript, cookies, etc, the login works everytime. I assume, everything is wrong with your browser settings. Did you made any changes these days, that could be the reason? Maybe you installed some plugins?
    Please delete your cookies, to see if the problem still exists. Also you can try to switch of and on JavaScript. Is there a option to create a new profile with standard settings?
    B.t.w I write this post with opera for testing it. It´s a long time i ago, i tried opera the last time and it´s working and looking very great. It even seems to be faster than firefox...think i will give it a try to be my next second standard browser:)
  3. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    Got the same problem with Firefox last week, tried it with different PCs. Everytime I logged in with FF, I was kicked out after the redirecting process to the main site. When I tried to login with IE7, everything was working fine.
    As far as I know, Nima got the same problems with FF for a short period of time...
    The problem existed only for one day - since that, Firefox is doing its job fine again.
    Regards,
    Chris
  4. egoexpress
    Me too with FF, IE worked fine...but just for one day. Now everything works as usual again :?
  5. RaceRay
    23,862Coins
    That was the moment when i made some login modification, concerning the remember me login function for persistent login. Was not the hole day, only one hour of time :)
    If i remember rightly you didn´t tel me that your mobile phone has opera on board :?
    Martin and Piotr, please let me know which version of Opera you use!
    Also it would be very helpful if someone else can test the strange behavior with Opera, too. http://de.opera.com/
  6. RaceRay
    23,862Coins
    Please delete all cookies and try again. If that doesn´t work deactivate cookies for x-sim, and see if the error still occurs.
    Let me know the result, i need it for a solution!
  7. mrpio
    mrpio New Member
    Works OK after I deleted all cookies!
  8. RaceRay
    23,862Coins
    Martin, hast Du jetzt auch nochmal die cookies gelöscht?
    Gruß
    René
  9. RaceRay
    23,862Coins
    Nice dude :D Dein Browser hat mich schon fertiggemacht*grins* Dann können wir ja endlich mit dem Portal und der community integration weitermachen ;)
