makes plugin F1 2021 Codemaster
Discussion in 'SimTools Plugins' started by pfm21, Jul 28, 2021.
  1. pfm21
    pfm21 pfm21 build 3dof dinamic
    356Coins
    Hello everybody. I state that I am not an expert but I have read the instructions to be able to make a plugin. I followed the instructions and compiled. the game is patched and Simtool runs when the game is open, the plugin is valid but does not read any values in the tuning center. can someone give me a hand
    maybe there is something still to be filled out that I cannot understand. thank you all
    plugin is in attached
  2. pfm21
    356Coins
    Can help for finished it?
  3. pfm21
    356Coins
    I think that problem is that game running only on dx_12. Or not?
  4. pfm21
    356Coins
    I didn't understand how to see the game's udp outsim package and then place it in the output variables, Roll_Output, Pitch_Output, etc ...
    can someone give me some indication? thank you
    147,884Coins
    +10,880 / 54 / -2
    @yobuddy can you please give some guidance.
  6. yobuddy
    49,199Coins
    Hi Guy's,
    I believe the new output structures are listed here in a docx file:
    https://forums.codemasters.com/topic/80231-f1-2021-udp-specification/
    But I have not had time to make an account and download it (if its still available?)
    (if someone is able to grab the file, please post it here :grin)
    After I take a look at the file, I should be able to help more.
    I'll can see what I can do this weekend, we are close to having the custom v3 back-end all setup to use!
    Some of the new stuff is pretty slick!
    Chat soon!
  7. pfm21
    356Coins
    I found this I don't know if it can be useful
    https://www.npmjs.com/package/f1-2021-udp
  8. pfm21
    356Coins
  9. yobuddy
    49,199Coins
    F1 2021 Test plugin (using the 2018 output structure as I know it works).
    Let me know how it goes guy's.
    (After I get some feedback on the plugin, I can update it to the 2021 output structure .)
    Take care!
  10. bruno1210
    bruno1210 schumi06
    75Coins
    Hello, thank you, I'm testing
  11. Carsource
    Carsource New Member Gold Contributor
    - 41Coins
    I will start testing today ! I will come back with feedback as soon as possible, thanks a lot mate ;)
  12. sitaracing
    sitaracing New Member Gold Contributor
    - 165Coins
    Hi, thanks to the creator of the F1 2021 plugin, it works perfectly.
  13. sitaracing
    - 165Coins
    Also to thank in general all those who are dedicated to creating the plugins, so that people like me, who understand the basics of this, can enjoy our jovi, and in my case passion for simulation racing. A pleasure to be able to enjoy this community of people always ready to help others.
  14. Richard Max
    Richard Max New Member
    83Coins
    2DOF, 3DOF, SimforceGT
    thanks for helping us.
    I tested the plugin, and was wondering if it is possible to help with some things.
    It works fine, but because it uses legacy mode, it doesn't work on my team, and if you use it together with a dashboard, like simhub, you need to put it as f1 2017, because if you put 2021, the simulator stops working.
    would it be possible not to use legacy mode? and use 2021 mode in the game so that the dashboard can work?
  15. bruno1210
    bruno1210 schumi06
    75Coins
    thank you for plugin f1 2021 works wonderfully top a big thank you to you
  16. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Did you use simhub as proxi?
  17. bruno1210
    bruno1210 schumi06
    75Coins
    Yes simtools + simhub perfert
  18. pfm21
    356Coins
    Have you select "Legacy" in f1 2021 settings?
  19. ALBERTO MARTINEZ PALAZON
    ALBERTO MARTINEZ PALAZON New Member Gold Contributor
    - 55Coins
    HELLO good morning I have been reading the forum, I have seen two files to download, the one that you have tried and it works is the one from @yobuddy?
  20. bruno1210
    bruno1210 schumi06
    75Coins
    Hello, yes it works perfectly with telemetrie 2018
