MDL-BDC24 Controller works?
Discussion in 'SimTools compatible interfaces' started by racerg, Apr 22, 2011.
  1. racerg
    racerg Going too fast... SimAxe Beta Tester Gold Contributor
    Sound designer for Olympics. Electronic engineer,
    Los Angeles, California- USA
    - 33Coins
    3DOF, AC motor, Motion platform
    Hi:
    I am new here and this is my first post. I am an electronic engineer and race car driver...
    I am building my first sim and want to know if this controller will work with X-SIM: TI MDL-BDC24, brushed motor controller...
    If it will work, it should be good, as it is the entire controller, motor driver in one unit and can handle a lot of power and seems very flexible.
    It does have a serial interface (CAN as well as RS-232). You can also driver it w/analog voltage or PWM.
    Help would be appreciated...
    Thanks!
  2. bsft
    It looks like it could have potential. It seems to have a feedback wire up spot, which is good.
    However, the more experienced members of this forum would give a better answer.
  3. racerg
    - 33Coins
    Hi:
    Thanks for the reply! Yes, it has an analog (pot) and digital encoder input for feedback.
    I am primarily concerned about the serial interface over RS232...
  4. Frakk
    Frakk Active Member
    328Coins
    We need to know the communication protocol of the controllers, which is not specified in the datasheet.
  5. eaorobbie
    20,473Coins
    Reading a bit more on site a mirocontroller is still needed to send a pwm to to module and a direction.
    Therefore would work as speed controller ie hooked back to a K8055 as an example. What is unclear is documentation on site without purchasing or asking the question on their forum is that with a software program you can control the card just like what we want to but is xsim able to talk to the card without a plugin ie uso still unclear mate ask them, or maybe a developer might be able to look into it. If ya work with electronics build tronics setup, parts pricy here in aussie ($190) without pcbs but xsim can talk to it perfectly and plenty of support. I started with the Jrks which do exactly what i wanted in a frex module but to go much bigger in sim wieght i need power, long live tronic, when my part arrive into australia my joyrider will have motion, sick of pulling a stick around to get motion, Setup as a big sit in joystick.
    Sorry to go on, but without a direct plugin cant see it working as a standalone controller.
  6. Frakk
    Frakk Active Member
    328Coins
    It works as a closed loop controller. Just find out the RS232 commands and if the USO can parse it or not.
    eaorobbie: You are better off with the JRK. If you are going to build the AMC, skip the dMSHB part and use a pololu or sabertooth driver if you want more power.
  7. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Thats is the problem 8)
  8. bsft
    I am throwing the pololu 12v12 jrk's at 19amps currently and they are holding up on my joyrider frame, be it with heatsinks and fans!
