Microsoft .Net Framework 4.4 problem
Discussion in 'SimTools DIY Version' started by gigi, Oct 30, 2015.
  1. gigi
    gigi Active Member
    905Coins
    2DOF, JRK, 4DOF
    Hallo to everyone.
    Since today I ve this problem: when I start Game Manager I recevive the following error mmessage fro Microsoft .Net Framework:
    "Eccezione non gestita nell'applicazione" -
    "unhandled exception in the application"
    The details of arrorare the following:
    Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
    sono riportate in fondo al messaggio.
    ************** Testo dell'eccezione **************
    System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
    in SimTools_GameManager.Mod_GameProfileLoader.GameProfileChanged()
    in SimTools_GameManager.frmMain.cb_GameSelection_SelectedIndexChanged(Object sender, EventArgs e)
    in System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
    in System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
    in SimTools_GameManager.frmMain.frmMain_Load(Object sender, EventArgs e)
    in System.EventHandler.Invoke(Object sender, EventArgs e)
    in System.Windows.Forms.Form.OnLoad(EventArgs e)
    in System.Windows.Forms.Form.OnCreateControl()
    in System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    in System.Windows.Forms.Control.CreateControl()
    in System.Windows.Forms.Control.WmShowWindow(Message& m)
    in System.Windows.Forms.Control.WndProc(Message& m)
    in System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    in System.Windows.Forms.ContainerControl.WndProc(Message& m)
    in System.Windows.Forms.Form.WmShowWindow(Message& m)
    in System.Windows.Forms.Form.WndProc(Message& m)
    in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Assembly caricati **************
    mscorlib
    Versione assembly: 4.0.0.0
    Versione Win32: 4.0.30319.18063 built by: FX45RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Versione assembly: 0.1.2.0
    Versione Win32: 0.1.2.0
    Base di codice: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    Microsoft.VisualBasic
    Versione assembly: 10.0.0.0
    Versione Win32: 11.0.50709.17929 built by: FX45RTMREL
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Versione Win32: 4.0.30319.34238 built by: FX452RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Versione Win32: 4.0.30319.17929 built by: FX45RTMREL
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Versione Win32: 4.0.30319.34251 built by: FX452RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Versione Win32: 4.0.30319.34270 built by: FX452RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    Versione Win32: 4.0.30319.34245 built by: FX452RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
    Versione Win32: 4.0.30319.18060 built by: FX45RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Versione Win32: 4.0.30319.34234 built by: FX452RTMGDR
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PluginAPI
    Versione assembly: 1.0.0.0
    Versione Win32: 1.0.0.0
    Base di codice: file:///C:/Program%20Files%20(x86)/SimTools/PluginAPI.DLL
    AssettoCorsaEA_Plugin
    Versione assembly: 3.0.6.0
    Versione Win32: 3.0.6.0
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/AssettoCorsaEA_Plugin.dll
    DirtRally_Plugin
    Versione assembly: 1.0.4.0
    Versione Win32: 1.0.4.0
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/DirtRally_Plugin.dll
    RichardBurnsRally_Plugin
    Base di codice: file:///C:/Users/gigi/AppData/Local/SimTools/GamePlugins/RichardBurnsRally_Plugin.dll
    mscorlib.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
    Base di codice: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Debug JIT **************
    Per abilitare il debug JIT, è necessario impostare il valore
    jitDebugging nella sezione system.windows.forms del file di configurazione
    dell'applicazione o del computer (machine.config).
    L'applicazione inoltre deve essere compilata con il debug
    abilitato.
    Ad esempio:
    <configuration>
    </configuration>
    Quando il debug JIT è abilitato, tutte le eccezioni non gestite
    vengono inviate al debugger JIT registrato nel computer,
    anziché essere gestite da questa finestra di dialogo.
    I don't kwon how resolve this bug. Thanks for your suggest
    regards
    147,878Coins
    +10,879 / 54 / -2
  3. gigi
    gigi Active Member
    905Coins
    2DOF, JRK, 4DOF
    Thank you. I tryed to do how you suggested and now it work again.
    Perfect' thanks
  4. gigi
    gigi Active Member
    905Coins
    2DOF, JRK, 4DOF
    Another question: I reinstall assetto corsa in a new directory . So i need to remove old patch and select the new patch folder. But in game manager windows the botton "remove patch" is not enabled. So I try to remove manually in C:\users\mycomputer\Appdata\local|simtools\..... . But when I come back to game manager windows to repatch the game with a new folder the botton "pathc game" is not enabled. How can I do? thanks
    147,878Coins
    +10,879 / 54 / -2
  6. gigi
    gigi Active Member
    905Coins
    2DOF, JRK, 4DOF
    Problema solved following the earobbie's advice. Thanks
  7. Kenshiro27
    Kenshiro27 Active Member
    19Coins
    Hello
    I have the same worries as you
    can you tell me what worked reinstall simtools or update framework
