Question minimum yaw angle?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by ilciumbia, Jul 22, 2024.
  1. ilciumbia
    ilciumbia Member
    Engineer
    181Coins
    Hi all,
    I am working on adding yaw/traction loss to my sim, but I am wondering: what is the minimum angle to obtain a noticeable effect? Could +/- 10 degrees be enough?
    Thanks!
    147,002Coins
    +10,844 / 53 / -2
    That could work, in my view it is important the motion is fast and accurate.
  3. ilciumbia
    ilciumbia Member
    Engineer
    181Coins
    My idea is to let the u-joint rotate on the vertical axis, the extent would be limited to the excursion allowed by the two ball joints which is around, as stated, +-10 degrees... I hope the ball joints won't pop out though... I might have to add a mechanical endstop...
    147,002Coins
    +10,844 / 53 / -2
    That is yaw not traction loss and binding sounds like a real risk with that sort of limited implementation.
  5. ilciumbia
    ilciumbia Member
    Engineer
    181Coins
    Yes, you are right, after thinking about it last night I decided I have to go for something more traditional and less creative...
