Question Motion Cueing ?
Discussion in 'SimTools Pro & Entertainment Version' started by Gadget999, Feb 19, 2022.
  1. Gadget999
    12,072Coins
    Sim tools works by performing positional movements that follow the output from a game
    Lots of professional sims use motion cueing
    This is where a series of pre defined movememts are played out depending of the way the driver is performing
    Eg braking, cornering, oversteer, understeer
    Has anyone implemented motion cueing in a project ?
    Can sim tools trigger motion cues ?
    Is there any advantages ?
  2. Gadget999
    12,072Coins
  3. yobuddy
    51,374Coins
    I personally think of cued events like the rumble motors in a game-pad, and I do really think cued events make sense for some things, like Video Ride Playback.
    It would be a blast to be able to trigger feet ticklers, misters, strobe lights etc, all triggered from a video ride film. :thumbs
    But for a simulator, we want to just reproduce exactly whats happening on the screen as close as we can. One problem with using triggered events, is we can introduce motion sickness, where the predefined events causes the sim to move unlike whats happening on the screen.
    Let's say we just want to add some rumbling when we are off road or something.
    Again, I would just want to increase the resolution and or speed of the axis so they simply get more rumbling when off road.
    Just my 2 cents anyway...
    (If it's a penny for your thoughts, why do we have to put in 2 cents? Seems like a scam) :grin
    Take care,
  4. Gadget999
    12,072Coins
    Hi Youbuddy,
    thanks for your reply - I also think the motion cues would not relate to the simulation and would feel a bit odd - but the people that use it say the opposite - it reduces motion sickness !
    I would have to build some software to analyse the outputs and then activate a suitable cue ie acceleration accordingly
    this video shows a sophisticated sim doing 2 different models for a u turn - the second seems very complicated
    and again a simple acceleration
    this sim obviously has a lot more movement than most !
    (also used as a helicopter sim )
    I will gladly pay a dollar for your thoughts !
    153,045Coins
    +11,116 / 56 / -2
    Personally I consider this to be somewhat schematics, with a dash of marketing fluff, in that what is being considered is how washout is utilised.
    Stepping back for a moment, washout is itself a false cue that aims to hide that fact by falling below perceptual acuity of humans, by exploiting physiological and psychological processing weaknesses.
    Washout, in one form or the other, is used in-turn to hide the physical movement limitation of a particular rig design. In other words it is all about compromises and physical limitations, in circumstances where it is impossible to accurately recreate all experienced real world forces in a simulation.
    From the user perspective context also matters. For example, an unconstrained passenger on a big enough aircraft in a sustained dive will experience that movement as weightlessness, little input at all, while at the same time the strapped in pilot will have a great deal of physical input signals. I am cheating a bit, even IRL the aircraft does not have an endless axis to sustain the weightlessness, 'as it is itself a fancy simulator for what is a simulation'.
  6. Gadget999
    12,072Coins
    "From the user perspective context also matters. For example, an unconstrained passenger on a big enough aircraft in a sustained dive will experience that movement as weightlessness, little input at all, while at the same time the strapped in pilot will have a great deal of physical input signals. I am cheating a bit, even IRL the aircraft does not have an endless axis to sustain the weightlessness, 'as it is itself a fancy simulator for what is a simulation'.
    Interesting, the difference a seatbelt makes !
  7. wingert
    wingert Active Member
    702Coins
    4DOF
  8. Gadget999
    12,072Coins
    Yes Cruden do things differently - thier software Pantera sits ontop of an E2M technologies network that talks to servo motors
    Pantera evolved from racers.nl
    certain movements on the Cruden are automated like when the car oversteers it appears to use to perform the same manouver. The Drivers seem to like this motion
  9. wingert
    702Coins
    4DOF
    I think your second solution is only possible by the great amount of travel available.
    153,045Coins
    +11,116 / 56 / -2
    If you use washout predicatively, the greater the axis travel the more the possible benefit, but there are also other factors I would suggest are limitations, and when it comes to DIY, far better alternate options.
    Take a very basic 2DOF and consider surge. If you are headed down a strait and have a known breaking area approaching then you could use washout predicatively and subtly tilt the rig back, so there is more axis range for surge than would otherwise be available. But the washout needs to below perceptual thresholds and even then there is a limit, as at a certain attitude of tilt a user will notice it.
    So in my view, a small benefit for a controlled circumstance, and the greater the axis range the bigger the benefit if those conditions are not exceeded, though speed and precision of movement also come into play.
    But for DIY motion simulation, designed for large range of games and possible rigs, there are better and more efficient options for generating actual sustained motion cues that don't rely on but can compliment tradition axis, such as a motion controlled harness or G-Seats. Those will give far more bang for your buck in providing a sustained surge cue in a way that rig movement alone can't.
  11. wingert
    702Coins
    4DOF
    In my imagination in a stable high speed cornering drivers gets only, through the interaction of 2 dynamical conditions (driver versus car), a sustained force from the outside of curve,if oversteer arise that force disappear suddenly and if the car spins it push him from inner side into a rotation.
