Motion Platform DIY
Discussion in 'DIY Motion Simulator Projects' started by Random_Cat, Jul 28, 2023.
  1. Random_Cat
    Random_Cat New Member
    32Coins
    I am currently working on an DIY motion platform for my room. I have started working on it. In the end it should be controlled by 4 morors pusing up down left right ... . I want to test in dirt and many more.
    148,565Coins
    +10,902 / 54 / -2
    I am looking forward to following your project.
    What motors, PSUs, control boards and code do you plan on using?
  3. Random_Cat
    32Coins
    I am not shure yet
    148,565Coins
    +10,902 / 54 / -2
    Doing plenty of research is time well spent, check out other member projects for inspiration and to see what hardware was used: https://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    Use the Enhanced Google Search on the Recent page to dig out thing you are particularly interested in, it is handy to sort the results by date so you are reviewing current rather than old information.
    Before you start ordering anything post a sketch of what you plan to build and what hardware you intend using, that way members can lend their expertise and suggest what is a good choice and what may not be, or designs considerations you may not have thought of.
    The Design section of the FAQs is a great place to start: https://www.xsimulator.net/community/faq/design-considerations-resources.24/category
    And you can use tools from there like SimCalc to help you work out the tradeoffs in design Vs physics, as well as what sort of motor specs may be needed for a given design and performance.
    The Build section of the FAQs is also very helpful: https://www.xsimulator.net/community/faq/building-resources.12/category
