MOTION SIMULATOR
Discussion in 'Rock n Ride simulators - Outdated' started by delpier, Jan 10, 2007.
  1. delpier
    delpier New Member
    Is it possible that simulator works with game not with wheel.
    Example:
    You are driving on snow, ice and you turn your wheel hard on left, if simulator works with wheel in that case chair will lean hard left or right. But in realistic drive your car wount turn hard left on ice, so in that case you should turn hard left but car goes forward, in that case your chair should not lean on left or right.
    Is posible that chair works with game not with your wheel
    I would like that chair turns when should in game not when I turn my wheel.
    I hope you uderstand what I want to know.
    I would like to buy chair, if is possible to connect it on game lfs, you can see in game forces. Is possible that chair works with this forces, not with my wheel.
    I saw on page http://shop.rightthing.nl/index.php?mai ... cebd3b8f00
    that chair what means that you can buy it with double power with 2 compressrs??? costs 250 eur extra.
    Where can I buy chair I am from Slovenia. I was looking for force-dynamics but it is a little to exipensive.
    thx, for answer
    pier
  2. egoexpress
    Hi delpier,
    wellcome in our forum!
    I know what you mean :mrgreen:
    1. If a game specific plug-in is available, the simulator only moves, when the vehicle/plane/ship moves. (The way you want it)
    2. If there isn't any plugin for your game, you can either use just directx effects, or mix directx effects with your joystick. (temporary solution till a plugin is available)
    I'm trying to translate the x-simulator.de website as fast as possible.
    If its unclear, please ask again.
    regards
  3. egoexpress
    delpier,
    Be aware that the simulator you are going to buy, is not a plug&play device.The stock equipment of the RnR does not support ForceFeedback.
    You have to make an 'up to date' usb circuit board by yourself.
    You can use a ready assembled Velleman K8055 as well.
    We could help you to get it working ;)
    Imho, if you could get any silent compressor with 6-8 bar and with a tank, you'd going better as with these stock compressors.
    regards
  4. delpier
    delpier New Member
    thx
    Do you have chair?
    Who works this chair? Manufacture?
    I will to buy it. Do you know for any newer simulator. I hade this yellow chair, I know that this I can change with realistic renn chair.
    I will buy logitech g25 next week. Do you think that chair will work with ps3?
    Where do you buy chair. On what details I must be carful. Exist newer and older chair?
    thx for answer, sorry for my bad english
    pier
  5. egoexpress
    Manufacturer is bankrupt, cause the stock controller was a piece of crap.
    Just in the messie Joystick mode without force feedback
    There are only old chairs :mrgreen:
    I would ask them, if you could buy the seat whitout electronics for less money. If you could find some good pneumatic cylinders you dont need even the stock ones.
    Do you have electronic, programming skills? Please have a look at first at this simulators and then decide, if you want to have one. Its fun, but a lot of work!
    http://www.x-simulator.de/forum/bilderg ... r-f20.html
    regards
  6. delpier
    delpier New Member
  7. delpier
    delpier New Member
    I dont have skills of programing...
    But I am open mind, and I am a quick learner.
    Thank you for all, for now ;)
  8. delpier
    delpier New Member
    FREX GP
    Shopping Cart
    1 x SimConMOTION+Damper Kit
    1 x AC/DC adapter 12V
    1 x Cockpit
    1 x Hshift+
    2 x Spring for Hshift+
    1 x Shaft Brake Cylinder
    2 x Potentiometer 500k
    1 x ShiftStand
    1 x Wheel adapter kit
    1 x Deluxe ProPot
    1 x SimClutch+
    1 x Clutch+
    1 x Pedal Outright
    2,392.02EUR + SENDING COSTS
    This is currently the only shipping method available to use on this order.
    Japanese Postal Service (2 x 21.435kg)
    EMS 413.39EUR
    TOTAL 2.800 EUR
    I hope I didnt forget to order some part. I have at home wheel driving force pro, I saw that you make wheel from that wheel dfp.
    I was starting to sell this wheel and buy new g25. But I saw that I will need it.
    What do you think? Is this possible to buy ion Europe or only in Japan?
    What is overhead pedal unit?<(posisible formula cockpit or ovrhead)
    pier
  9. egoexpress
    delpier,
    We are not the manufacturer nor seller of this simulator. If you want to buy it, go to frex.com/gp
    regards
  10. delpier
    delpier New Member
    sorry, I know I just wrote to hear your comment.
    Thank you again for all infos!!
    regards,
    Pier
  11. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Welcome to our Forum,
    Ontop of the 2.800 EUR you will have to pay additional import-duty (Here in The Netherlands appr. 10%-15% and ontop over the total (2.800 + 15%) you will probably have to pay turnover Tax (here 19 %)!!
    -Further more you will need a heavy AC/DC converter -12V / 12V for the actuators (please order it through FREX).
    -Don't forget the SimConMeter (this is a kind of mastercontrolboard , the SimConMotion will connect to SimConMeter as a slave-board)
    -You will have to add your own wheel
    -You will have to add a racechair
    So total will this way come up to about appr. € 4.500,--!!
    Greetings,
    Jelle
  12. egoexpress
    *hint* for frex information go to racesimcentral forum and search for frex and/or simconmotion ;)
    http://forum.rscnet.org/forum.php
    regards
  13. delpier
    delpier New Member
    I found that forum, there is planty to read about frex.
    I am reading.
    Do you have any expiriance with frex motion sim?
    It is not that cheap when you calculate all togethar. They are working on new wheel, produced by frex not on logitech one.
    pier
  14. delpier
    delpier New Member
    What are differences between frex wheel/pedals and vpp?
    Do you have experiencess with G25, frex, vpp?
    I saw on video that old logitech dpf is much slower than g25. Do you think that would be good start if I buy frex moton system(motion, simbase, cockpit) and g25. ? Or is waste of money and better buy all from frex or vpp?
    pier
