Motor Limits Fix ???
Discussion in 'SimAxe Motion Controller' started by lcturkey, Aug 11, 2015.
  1. lcturkey
    lcturkey Member
    163Coins
    Hi to all,
    When I pull the slider to -100 motor continue to turn and doesnt stop at a point. it is same at +100 too but motor turns to opposite side . How Can I fix my motors to 180 Degree ? Also when I connect the pots to motors it is same. it brake the pot and continue to turn. I never get a movement like this at the video.
    I really need help so much about this. What can I do ?
    154,639Coins
    +11,206 / 57 / -2
    Are you using wiper motors and if so are they ground isolated? Are you using an Arduino and if so what code are you running?
    Posting some photos of the wiring and settings screenshots would also help troubleshooting.
  3. hooshang
    hooshang Active Member
    275Coins
    and also you may check this:
    open Game engine,go to Axis assignments and Tab --> Axis limiting
    try to reduce" Amount of Axis to Use" and check again to find proper number
    regards
    Hooshang
  4. yobuddy
    51,734Coins
    hi @lcturkey,
    What interface are you using?
    Are the pot's connected backwards?
  5. Nick Moxley
    17,057Coins
    we need LOTS more info to help turkey
  6. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    Why this process is necessery especially for?
    154,639Coins
    +11,206 / 57 / -2
  8. hooshang
    275Coins
    cause many different products are in the market and you can adjust them easily in this way
  9. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    As I see, limits the movement. And doesnt use the all movement interval. OK
