Question Motor Shudder
Discussion in 'New users start here - FAQ' started by Denis Mowberry, May 2, 2025.
  1. Denis Mowberry
    Denis Mowberry Member
    New Zealand
    99Coins
    Hi can anyone help with my new problem. I have rebuilt my control box with a new ardueno uno and ibt2 controllers but now my motors shudder uncontrollably. I have no idea what I have done wrong or where to start looking. Any suggestions gladly accepted.
    151,443Coins
    +11,038 / 56 / -2
    Have you double checked all wiring?
    Have you setup SMC3 from scratch?
  3. Denis Mowberry
    New Zealand
    99Coins
    I went into smc3 and installed on to the new uno the same settings as the old one . I will recheck the wiring again
  4. Denis Mowberry
    New Zealand
    99Coins
    I have reset the system to control only one motor unplugging all the other wiring and still it is shuddering could it be a faulty Ardueno uno board
  5. Denis Mowberry
    New Zealand
    99Coins
    Sorry I should have added that when I smc3 on and run a sine wave the motor follows the line as it should but with the shudder I have also just found out that as soon as I turn the power on even without having the smc3 software running the shudder is the same. could it be a power supply problem.
    151,443Coins
    +11,038 / 56 / -2
    Is it possible there is an issue with electrical interference?
    Additionally, other members have reported a lot of issues with ibt2 controllers, so do check them very carefully.
  7. Qui
    Qui New Member
    - 144Coins
    IBT2 is a cheap device so it has many limitations, needs to be installed correctly to optimize, you can refer to the parameters on youtube
    151,443Coins
    +11,038 / 56 / -2
    I appreciate your video is trying to suggest some generic settings range for SMC3.
    However I feel your video misses the whole point of the SMC3 interface, and that is to allow individuals to fine tune settings for their specific hardware, nor is reference made to the initial recommended SMC3 setup steps: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
  9. Qui
    Qui New Member
    - 144Coins
    Yes smc3 is very customizable, but it will be difficult for beginners, this is just my recommendation,
    151,443Coins
    +11,038 / 56 / -2
  11. Denis Mowberry
    New Zealand
    99Coins
    Thanks for the help I have started from scratch and reset all the settings and two motors are fine the 3rd has a faulty potentiometer which is an easy fix. Again thanks for the help
