Motor won't stop rotating
Discussion in 'Commercial Simulators and Peripherie' started by Clayton2318, Nov 10, 2018.
  1. Clayton2318
    Clayton2318 New Member
    Delaware
    307Coins
    Joyrider
    Hi guys,
    Super new to motion sims. I bought the 3DOF kit from DOFREALITY.COM several months ago and have actually yet to use the rig.
    The latest issue is when I turn it on the front left motor just keeps spinning. This made the rig do a nose dive to the front left corner. It was stuck so I took off the arm and recorded a video, as you'll see the arm just keeps spinning. Also the traction loss is stuck to one side.
    I thought maybe I mixed up the axis, but I checked and it's just as the same as the forum here suggests for iracing.
    Can someone please advise? At the very least is like to get the motors back to zero so I can use it as a chair ... Which I've been doing for months now :',(
  2. Clayton2318
    Delaware
    307Coins
    Joyrider
    Sorry, trying to figure out how to upload a video that isn't too large. I'll have one soon.
  3. Clayton2318
    Delaware
    307Coins
    Joyrider
    It seems I can't upload MP4's, so to explain the motion, ... if I were tied to the arm of the motor I would be doing front flips. It's trying to pull the rig down. The problem is, it never stops. So it just rotates at a constant speed, "front flipping"
  4. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,239Coins
    147,878Coins
    +10,880 / 54 / -2
  6. Radioproffi
    Lviv
    1,563Coins
  7. Clayton2318
    Delaware
    307Coins
    Joyrider
    I'll contact DOF sales team - hopefully they can provide some support. Not exagerating when I say I've not even used this rig for a total of 2 hours yet. It's been nothing but problems since I got it.
    Video below
  8. Vince Emmery
    Vince Emmery New Member
    68Coins
    Hi Clayton,
    I have a H2 model and mine is doing exactly the same
    Did you manage to identify the problem and get a remedy ?
    thank you
    147,878Coins
    +10,880 / 54 / -2
    Have you contacted DOFreality:
  10. Vince Emmery
    68Coins
    Hi Yes,
    They advised me to see if the green line is moving in smc3 ,
    I installed the software and changed the com port to 5 but get a message stating it could not connnect.
    It was getting late so i stopped and will have a try today.
    They mentioned not having srs running.
    147,878Coins
    +10,880 / 54 / -2
    Everything else should be closed and SMC3 run alone, otherwise you can have a port conflict.
    I am presuming you checked for the correct port in Device Manager.
