Motorcycle Controller
Discussion in 'DIY peripherals' started by teeds, Mar 7, 2016.
  1. teeds
    teeds Member
    590Coins
    Here's my build, been using it for about a year and is the first thing like this I've built. A few bits fell off, went wrong or performed badly along the way but it's now solid and gets used lots.
    Testing the basics with a seat and foot controls, it all worked well.
    Got a mate to provide bearings etc and put this together for me. The idea was to connect this to the seat section.
    After wiring and assembly
    Then decided due to natural pushing and pulling I couldn't help myself doing when playing, and portability, made a desk mount with a forward backward pivot.
    Recently broke my leg and while healing and playing had to use a normal desk chair and found this far more comfy. So chopped off the top of the base made it more adjustable to use with said chair all the time
    It ain't much to look at but works great with GPBikes and my favourite MXBikes shown here.
    • Like Like x 11
    • Winner Winner x 7
    • Creative Creative x 3
    147,998Coins
    +10,884 / 54 / -2
    A brilliant bit of specialist peripheral originality!
  3. rattler
    rattler
    Impressive setup!
  4. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    96Coins
    Good work and good rig @teeds !!:D:D:thumbs
  5. stevemontuno
    stevemontuno Active Member
    1,461Coins
  6. bruce stephen
    general contractor
    michigan
    9,112Coins
    Very cool. Does this have ffb. Looks very fun.
  7. teeds
    teeds Member
    590Coins
  8. bruce stephen
    general contractor
    michigan
    9,112Coins
    feedback or not i like it.
  9. teeds
    teeds Member
    590Coins
    With GPBikes this time....
  10. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    Looks awesome. I'm about to dismantle a bicycle to start one of these. It has twist gear shifters so I'm hoping I can eliminate the clicks and use that for throttle for now
  11. teeds
    teeds Member
    590Coins
    That'll work as long as you have enough rotation on the grip, good luck.
    Also the dev of these bike games is going to include VR support soon, if I don't vomit it could take things to another level..
    http://forum.piboso.com/index.php?topic=2765.msg60117#msg60117
    :thumbs
  12. PiaMan
    607Coins
    ya thats the sim I'm going use. So far gen 1 VR wasn't for me. It made me sick right away in a racing sim. The demo content looking around was fine.
    How did you make your throttle?
  13. teeds
    teeds Member
    590Coins
    Felt a little bit odd initially with VR in a sim myself but am loving it now with no ill effects. Other games can still make me feel odd, but with some kind of cockpit involved, it's fine.
    The throttle assembly is an aftermarket MX bike one. At the sensor end I've used 2 M6 bolts and skate board bearings joined by a bit of metal whose ends are shaped to allow them to be attached to the bearings with jubilee clips. One end is fixed to the back plate and the other end uses washers to clamp the throttle cable. The sensor consists of 2 magnets that spin with the fixed bearing around a hall sensor which is held in place by those ally plates you see in the video.
  14. PiaMan
    607Coins
    yup not enough rotation on the twist grip. I'll have to see if i can find something else. I was going to just rig up pots to the cables and attach one in the centre for steering. I'm hoping to get a bit of feedback by canabalizing a wingman steering wheel both for usb and motor control. I know it'll be weak but hopefully it will provide some road feedback.
  15. teeds
    teeds Member
    590Coins
    These might be worth a look - http://www.ebay.co.uk/itm/Moped-Ele...867320?hash=item2363a8e0b8:g:Kl4AAOSwezVW0CCe
    Not sure of the rotation of those but should be acceptable. The MX throttle I used had too much rotation initially as I think they're made with the carb slide in mind as the stop limit. But with these it's easy to put some solid material in there to get it just as you like (bits of wood in my case), also takes the stop load off the cable and clamps.
  16. PiaMan
    607Coins
    Hey thanks. That is a great find. I was going to rig up some mechanical thing to pull a pot but these seem to have the pot integrated into the grip. Much cleaner solution.
  17. LI JIAN HUI
    LI JIAN HUI Learn 2DOF maker
    CHINA
    351Coins
    2DOF, DC motor
    请问自行车这类游戏可以模拟吗,感觉不错还可以减肥!
  18. lcturkey
    lcturkey Member
    163Coins
    looks great. I also want to make a wheelie machine like that :)
  19. outrunner
    outrunner Run to get the race leader flag!
    father mother
    639Coins
    What interface did you use for this? Arduino maybe?
    If I can suggest you a game for moto simulation, go with Milestone Superbike 2001 ;)
  20. teeds
    teeds Member
    590Coins
