Motors vs valves?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by saucer78, Mar 1, 2016.
  1. saucer78
    saucer78 Member
    939Coins
    2DOF, Motion platform
    Noob here, learning bit by bit...
    One question that's been bugging me as I read up on motion platforms is the difference between the control of motors and valves.
    Is there a good tutorial or thread on the behaviors of each, or will their traits become more apparent once I'm able to play around with SimTools? (Gonna try to download it this week)
    Thanks!
  2. BlazinH
    16,622Coins
    Valves are an older technology that are being replaced by modern electronics driving electric motors that can do the job instead and often better. Imo, Valves are more complicated to work with too and it would likely cost much more money getting equivalent motion using them vs electric motors unless maybe you plan on lifting and moving a lot of weight.
  3. saucer78
    saucer78 Member
    939Coins
    Thanks for the insight.
    After a little more research, I've realized that many of the Stewart Platforms actually use electronic actuators, instead of hydraulic or pneumatic. Derp.
    So even though valve systems are becoming less popular, will SimTools support a more binary system that utilizes valves? I'm trying to help with some existing 2DOF units that boast 3 pneumatic rams and would like to replace their proprietary motion controllers with Arduino micro controllers...
  4. BlazinH
    16,622Coins
    It up to the sketch you put on your arduino(s) to control the valves themselves. Simtools just sends out position data and your arduino will take it from there. But yes, simtools can drive them too!
  5. saucer78
    saucer78 Member
    939Coins
    Awesome, thanks again!
  6. saucer78
    saucer78 Member
    939Coins
    Ok, so according to the SimTools Quickstart Guide, I'll need a motor controller (in my case, a valve controller) in addition to the Arduino?
    Or in my case of pneumatic valves, can the proper sketch have the Arduinos working as all-in-ones, like the boards from Pololu?
    This guy appears to have built a pneumatic JoyRider with an Arduino controller and "Pneumatic Valve Amplifier." Is that amplifier essentially the "driver" of a pneumatic system?
    The most frustrating part of learning a new technology seems to be finding the correct terminology. :confused:
  7. BlazinH
    16,622Coins
    Please post information about the valves you will be using if you expect a response. But I think probably all you will need is an arduino(s) and possibly some relays or opto-couplers.
  8. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,690Coins
    It,s inpossible to have good position with air (air compresses under pressure this is the problem)valves are slow about 20 commands a second.Fast speed control valves are expensife, With motors you can stay realtime in position and cheaper.Oil isnt old it wil stay but only for things that move a lot off mass Oil got no position problems!
    sorry for the bad english regards Ad
