Question Movement transformation
Discussion in 'SimTools Plugins' started by SimHouse, Mar 27, 2018.
  1. SimHouse
    SimHouse New Member Gold Contributor
    - 171Coins
    Hi All,
    I checked the SimTools configuration and found a nice solution to link forces and axes by a guide that define, which force belongs to a particular axes or rotation in a 3D coordinate system.
    My problem is, what about if I have a simulator, that the motors are not working alongside of these axes, but they are mounted between the chair and the base of the simulator in an arbitrary degree.
    As I remember, to compensate this, I need a rotation / translation matrix (matematics). How can I configure this?
    Regards
  2. value1
    14,178Coins
    Can you show a sketch of your configuration?
  3. SimHouse
    - 171Coins
    153,001Coins
    +11,116 / 56 / -2
    That is a traditional 2DOF shoulder mount seat shaker design, many members here have built one for use with SimTools: https://duckduckgo.com/?q=site:xsimulator.net 2dof shoulder mount seat shaker&ia=web
    As it is a 2DOF there is no third axis and I have no idea by what you mean by the following, can you please elaborate further:
  5. SimHouse
    - 171Coins
    I found this short declaration about the 6 forces and their names:
    https://www.xsimulator.net/community/faq/dof-angles-forces.15/
    1. assumption: the game itself provides degree information if the car should be pitched over (e.g.: on a hill...).
    2 assumption: the linear actuators expects linear position information: how many units should I go ahead or backward...
    Even the moving is linear, the mechanical construction allows to have pitch in a given range, but I have to calculate degree information into linear parameters. From my mathematical knowledge, the rotation matrix can be used for this purposes.
    Regards
    153,001Coins
    +11,116 / 56 / -2
