Multi axis
Discussion in 'Force-Profiler Simulator Control' started by CW, Jul 8, 2007.
  1. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Hello, I wonder if it is possible to run one computer with Flightsim and two force senders linking to two computers with force profiler on each to get 4 axis motion?
  2. ODDNAME
    ODDNAME New Member
    Hörby (Sweden)
    the software supports 4 axis? =)
    X-Simulator is a universal and free software to control pneumatic and hydraulic self-made simulators with up to 4 axis and soft-pneumatic.
  3. egoexpress
    @CW
    Hi, nice to hear something from you again ;)
    Force Profiler 2.0 will support multiple axes. Much more you'll ever be able to use ;)
    BTW: Sirnoname wont release it, until the Profiler 1.8 beta is tested. And its up to you all, to give him some feedback, if the soft is stable, or if there are some bugs...
    The current ForceProfiler 1.X supports 2 axes.
    But afaik you could start it 2 times. You have to assign the axes anyway.
    regards
    ego
  4. tronicgr
    tronicgr
    This means that it will support more than x,y axis output from USO?
    Can I have a link to the beta 1.8 version to test it too?
    Thanos
  5. egoexpress
  6. egoexpress
    To use 4 axis within the Profiler 1.8 you'll have to
  7. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Force sender
    Gidday,
    havent managed to open two forcesenders on the gaming computer yet, what is the trick there?
  8. egoexpress
    Afaik you dont have to.
    Just try to open the profiler on the control-pc 2 times, and you should receive data on both Profilers.
    ego
  9. CW
    CW Member
    Jack of all
    New Zealand
    14Coins
    Thanks sirnoname, that works.
