My 2 DOF Sim: Adding 3rd Drift axis + roll & elevation?
Discussion in 'DIY Motion Simulator Projects' started by Henning Piez, Nov 7, 2011.
  1. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    as you know, the human being is never satisfied with what it has archieved. So I have a very nice 2DOF sim, that makes really fun, but my head always thinks about modifactions. My wish that I ever had is a 3rd drift axis, but now I also think about puting the whole 2DOF (that works without track elevation changes yet) on another platform with two SCN6 with 50kg that gives me that elevation infos + a axis for drift. Do you have made some tries to invent such construction?
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,690Coins
    Hi
    scn6 50kg are to weak for heave (elevation)Look @ there force /speed curve.
    You could fit youre 2dof upon a brd06 sim www.brdsim.com ,with the use of
    supported precision round rail.
    It,s all in the stiffnes from the bridges,you could create more travel with wippermotors than expensive scn5/6 300mm stroke ones.
    regards Ad
  3. bsft
    or perhaps a 12 volt winch motor on the drift frame. It would have plenty of grunt to do so.
  4. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    I think I will only add the drift axis. Hard enough to make it effektive. The Sim is quite heavy yet, so it has to move quite light around one point locate in front of the pedals....
  5. bsft
  6. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,690Coins
    Hi
    This way you could create understeer to
    For cheap rails and bearings google with linearmotionbearings2008 :hi:
    regards Ad
  7. BartS
    BartS Member
    417Coins
    This is very good Adgun, I was going to implement a similar system for extending my 3DoF to a 6DoF.
  8. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,690Coins
    @barts
    It would be great to see that working soon.
  9. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    These days I forgot to answer, if I suceeded:
    here you go:
    more pictures here (and some more gallerys with all construction pictures with details)
    http://s1066.photobucket.com/albums/u413/PiezSim/Final Rig Showcase
    Panorama aus 3 Bildern, daher die miese Qualität
    http://www.youtube.com/watch?v=2srJXTwnRy4&list=UU9_0l62A-wQUU59XDqkZJiA&index=4&feature=plcp
