Necessary data rate to platform
Discussion in 'SimTools compatible interfaces' started by yeniuser, Nov 4, 2015.
  1. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    To design a control card apart from mentioned ones in the site.
    What is the telemetry data rate uplodated that send from PC to control card.
    For example every 10ms or 50ms etc...
  2. bsft
    What card have you in mind?
  3. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    Sir
    After getting understand the fundementals of the system, I will desing my own IO card.
  4. bsft
    Ok, carry on....... maybe @yobuddy can advise, or maybe @value1 has an idea
  5. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    Up to date
  6. yobuddy
    50,746Coins
    It depends on the rate you set it at.
    For example, with COM output, you can select a packet rate anywhere from 1 thru 50.
    hope this helps!
  7. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    Sir thanks for reply.
    1 thru 50 in ms unit, isn't it? Do smaller values have realistic response? Or more Vibration?
  8. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    Up to date .
