Need help with motion compensation
Discussion in 'Commercial Simulators and Peripherie' started by Yigal, Jul 15, 2025.
  1. Yigal
    Yigal New Member
    34Coins
    4DOF
    I have the Prosimu T1000 5sv and using it in vr. I tried everything to make the motion compensation working and with no luck. I'll appreciate some help and even willing to pay.
    I'm in NYC midtown area in case someone lives around!
    151,455Coins
    +11,038 / 56 / -2
    It would help if you explain in detail what approach and related hardware/settings you have tried.
  3. Yigal
    Yigal New Member
    34Coins
    4DOF
    GM,
    I've tried both openvr and openxr.
    I tried with the Witmotion and also with the physical tracker (Vive)
    Im using the simtools 3 and have the Varjo VR-3
    I don't mind connecting my PC so you can figure out what I'm doing wrong
    Thank you in advance !
  4. Joe Cortexian
    Joe Cortexian Active Member Gold Contributor
    1,033Coins
    I have a Quest 3 and OpenVRand OpenXR both work. I use my right controller which is attached to the rig. It doesn't just work it has to be enabled. I use OpenXR for MS flight simulator and OpenVR for everything else.
    If OpenXR is enabled and being used you should hear a voice counting down and then saying either motion compensation is enabled or failed. Do you get the countdown and message? If not figure out how to configure it in the INI file.
    OpenVR has a menu in SteamVR. It shows up as a gear in the menu next to "VR Desktop". If you don't have a gear it isn't installed correctly or its has been disabled by SteamVR. Check add-ons and see that OVRMC is instealled and enabled.
