Need help!!!
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by experya, Jan 14, 2014.
  1. experya
    experya New Member
    474Coins
    Hello everyone, I'm new is I'd like to build a simulator, but before I throw myself on the building would like to understand how it works the sofware. I'll explain I would like to do (from what I understand) use simtools + Arduino with Schield motomonster, demand and what code should I put on the Arduino board, and then you can try everything to pc without having the engine? I hope you give me a hand, thanks to all.
  2. bsft
    First thing to ask is what sort of frame design do you have in mind?
    Then what sort of motors are you considering?
    As for code, theres a few existing already for the arduino, have a dig around.
    And yes you can try it out with a small model and rc servos, a few people have done that, @eaorobbie , @Historiker , cannot think whom else has done one to test with.
  3. Historiker
    Michigan USA
    9,201Coins
    Hi Experya, welcome to Xsimulator.net
    To help answer your questions vis-a-vis Arduino-MonsterMoto-Simtools take a look at these forum threads.
    RacingMat has a successful Arduino code that works with the MonsterMoto; I have been using it for a year or so.
    http://www.xsimulator.net/2dof-motion-simulator-truck-wiper-motor-playseat/
    Rufusdufus has recently created an Arduino code and utility for working with that specific motor driver and Simtools. A ton of information can be found in his thread.
    http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    Both are extremely helpful people and are willing to answer questions or give advice.
    You came to the right place my friend.
  4. eaorobbie
    20,440Coins
