Question New setup Motor over rotating on startup
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Chrisd454, Dec 19, 2024 at 22:05.
  1. Chrisd454
    Chrisd454 New Member
    40Coins
    Hi guys new member here
    I have been working with the SMC3 and the IBT-2 controllers with 24v wheelchair motors
    I have been able to get my RH motor functioning properly
    On the left motor I can start the program for motion but as soon as I add some pvMmax to get the motor to start to rotate it takes off and over rotates and shuts down. I have checked and all wiring is correct. The potentiometer is working and all settings are the same as the functioning RH motor.
    Any ideas?
    148,577Coins
    +10,903 / 54 / -2
    Are you sure the pot is properly centred?
    If you swap the IBT2 to the other motor does the problem follow?
  3. Chrisd454
    40Coins
    Yes I have checked the center on the pot. I will swap the IBT2 in the morning and see what happens.
  4. Chrisd454
    40Coins
    I swapped the IBT2 and yes the problem is in the controller. I have a new controller on the way and bought a spare while I was at it.
    Thanks for the quick response
