News New turn key motion kit and rig with good performance, affordable and Compact size
Discussion in 'Commercial Simulators and Peripherie' started by Frank1999, Mar 8, 2023.
Tags:
  1. Frank1999
    Frank1999 New Member Gold Contributor
    45Coins
    4DOF
    Hi All,
    I am glad to introduce our new turn key poject: D-Mover H3, compatible for Simtool 2.x.
    As you seen in the picture, it is a 4 actuators but 3 DOF motion platform, the mainstream structure solution in the present market.
    How is D-Mover different?
    1. Self-developed drive control integrated electric cylinder:
    With special universal base
    The actuator parameter:
    Stroke: 130mm(5Inch)
    Speed: 250mm/s(Max)
    Loading capacity: 50~80KG(Adaptive to load)
    Max Acceleration : 2G
    Input voltage: 48V DC.
    2. Use DC 48V safety voltage. Here is the matched power box:
    Power box size: 25*30*15cm
    Power supply:1200W
    Input voltage: AC110/220V(depend on the buyer)
    Output voltage: DC 48V
    P.S.(It's only a power distributor, not drive controller box, our driver controller is integrated to the actuator).
    3. Turn key USB kit, easy plug & play
    This is a plug & play kit, USB connect, no additional hardware or DIY is needed. Very simple wiring, all you need is plug in, everyone can do it.
    4. Due to our speed and position double-loop control tech, this actuator kit bring us very good performance and immersion. Synchronization is also very good, almost no latency. Here is the video for the actual performance:
    5. Affordable low price with high quality
    To be continued......
