newbie at 2.0 version!
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by Chewe, Aug 25, 2010.
  1. Chewe
    Chewe New Member
    - 19Coins
    Hi, it's been long since i've used old v1.0 version! Congrats, it looks hard worked progress!
    Meanwhile i'm trying to use Universal Serial Output and i'm a bit outdated using old parsing. I used to enter ~255~~1~~x~~255~~2~~y~ for use two axis system, could someone tell me where to translate this line to new USO parsing?
  2. tronicgr
    tronicgr
    In the new USO you need to enter it as:
    ~255~~1~~a01~~255~~2~~a02~
  3. Chewe
    Chewe New Member
    - 19Coins
    Thankyou very much Tronic!
    Now it works like old days. Now i'm moving to add bluetooth support through this device: http://global.ebay.com/Mini_Bluetooth_W ... 50475/item
    The problem now is that i don't know how to map Bluesoleil COM5 assigned Serial PORT to Profiler. I've tried \\.\COM5, but it doesn't work. Do you know how should i discover the path name to map it?
  4. Chewe
    Chewe New Member
    - 19Coins
    edit_ On windows device Manager I've found what it's supposed to be Communications Port Details TAB, two Properties: Device Instance ID, and Hardware ID. with the following information respectively: [ROOT\PORTS\0001] and [{F12D3CF8-B11D-457e-8641-BE2AF2D6D204}\IVTComm].
    My guest was to enter the following line on AddComporttoList on ForceProfiler: \\?\ROOT#PORTS#0001#{F12D3CF8-B11D-457e-8641-BE2AF2D6D204}#IVTComm but it didn't work.
    Any Help would be appreciated!
