Question No Game input from Live for Speed
Discussion in 'SimTools DIY Version' started by Marc R, Feb 7, 2018.
  1. Marc R
    Marc R New Member
    Germany, Hesse
    232Coins
    I have got a problem with getting inputs from Live for Speed. I did run the game before i patched it and Game Manager shows "Game Running". Manual output testing also works fine, but if i play the game and turn on "Virtual Axis" nothing seems to move. My motors go to idle position instantly when i turn Game Manager "On" and it is connected to the game, which shows that something is happening. But after that nothing moves, neither in "Virtual Axis" nor the motors.
    Thank you for your support!
  2. Mick29
    Mick29 New Member
    143Coins
    Bonjour ,Vérifier que GameManager et GameEngine communiquent
    Il faut faire clic droit sur l'icone dans la barre des tâches et Tuning Center, choisissez votre jeu et normalement en jeu les valeurs devraient bouger .
    Hello, Check that GameManager and GameEngine communicate
    Right click on the icon in the taskbar and Tuning Center, choose your game and normally in play the values should move
  3. yobuddy
    49,199Coins
    Please post screen shots of your axis assignments settings buddy.
  4. Mick29
    Mick29 New Member
    143Coins
    En ce moment je ne suis pas sur mon ordianateur de simulation automobile,
    En lancant le jeu vous devriez avoir les valeur de Live for speed dans le Tuning center , sans cela rien ne ce passeras sur votre simulateur .
    At the moment I'm not on my car simulation computer,
    By launching the game you should have the value of Live for speed in the Tuning Center, otherwise nothing will happen on your simulator
  5. Marc R
    Marc R New Member
    Germany, Hesse
    232Coins
      File size:
      187.3 KB
      689
    147,878Coins
    +10,880 / 54 / -2
    While you have said you ran LFS first please un-patch it, close SimTools, re-run LFS for a couple of laps, close it re-open SimTools and re-patch LFS.
  7. yobuddy
    49,199Coins
    @Marc R.
    Default settings covered!
    But what about Live for Speed's settings?
  8. Marc R
    Marc R New Member
    Germany, Hesse
    232Coins
    Didn't do any special settings in Live for Speed. Didn't even know you have to set something.
    What do i have to set? Tuning Center also doesn't see any input.
    Thank You
    147,878Coins
    +10,880 / 54 / -2
  10. yobuddy
    49,199Coins
    The 'Default' axis assignments get copied for all new game plugins installed (as a starting point for that game if you will)
    But since Live for Speed comes with SimTools, you have to set it up also.
    Hope that makes sense buddy.
    Take care,
  11. Marc R
    Marc R New Member
    Germany, Hesse
    232Coins
    Thank you!
    That was it. Didnt drive a couple of laps. Just started it and drove a bit. After doing this it worked!
