Nolimits Profiles - 100mm SCN5 - by Master Yoda
Discussion in 'X-Sim² profiles' started by MasterYoda, Feb 19, 2009.
  1. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Game: rFactor
    Intended Sim Hardware: 2 SCN5 Frex-Style design (On-Road)
    Actuators: 100mm
    25% Limiter: Yes
    Math Plugins Used: 1:1 G-Force, Smooth washout, Logarithm scaler
    Designed for Specific Vehicle: N/A
    Includes Program Settings: No
    Includes Gauges: No
    Speed / Acceleration Values: 18100 / Accel: 257 (Fixed on Synaptrix)
    http://www.youtube.com/watch?v=5_qips5pFhg
    Disclaimer: It's simple. If one of these profiles harms you or your equipment, I am sorry but am not liable in any way. Use this profile / setting combination at your own risk. Do NOT use these profiles if your 25% limiter is not enabled.
    Profile based on Bvillersjr one, changed most of the settings/values to my taste (acceleration mix), included Smooth washout and Logarithm scaler plugins.
    Hope you guys like it.
    Cheers,
  2. clarkii
    clarkii New Member
    Hong Kong
    792Coins
    3DOF, SCN5
    Hi Master Yoda, thanks for the profile. I tried it and it works. Just one quick question, I opened your profile in Profiler (I used latest beta of X-Sim) and the s/w prompted the profile is outdated and recommended to increase the accelerator value given the higher resolution. Can u advise whether the adjustment is required and if yes what I should amend in your profile? Thanks a lot.
  3. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    I believe no adjustment is needed in this case, since the increase on resolution of the new x-Sim versions are not applicable to the injector.
    Just save the profile again and it will stop these msgs.
  4. leandroter7
    leandroter7 Member
    - 89Coins
    3DOF, 6DOF
    I made some mods on the older profiles for this game. Please try it
    bye
