ODESC V4.2 question
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Grunch, Mar 25, 2024.
Tags:
  1. Grunch
    Grunch New Member
    22Coins
    Hi, I have an ODESC V4.2, I was able to flash the device via cube programmer but I want to go back to using it as a BLDC controller, I tried loading the ODrive software from the ODrive website but it doesn't work as the device no longer shows up under /dev/
    Suggestions? There doesn't appear to be any place I can get the ODESC firmware which is bizarre.
  2. Grunch
    Grunch New Member
    22Coins
    Gah, I was using the memory editor and not the programmer in the MXCube software, was able to load the correct odrive firmware over USB. Now I get an annoying message about the device not being authentic when I startup odrivetool since it checks a hash attribute but I searched the github repo and it doesn't appear they poison the source code, I'm just assuming the provided firmware is the same though I suppose I could always compile from source.
