Odrive
Discussion in 'New users start here - FAQ' started by Walysson, Jul 12, 2023.
  1. Walysson
    Walysson New Member
    52Coins
    Arduino, 6DOF
    some doubts about ODrive, with the new board it has 56v.
    pro simulator 6dof
    generally needs a more responsive engine! with a higher torque right?
    an example (190kv)
    which has a consumption of
    (maximum 65 amps / maximum 2450 watts)
    with these caucles/2 motors on a board the consumption would be?!
    130 amps
    4900 watts
    Could this cause some poor performance?
    it makes sense?
    I had an idea these days and I'm going to share it on my profile, I'm just going to improve the drawings more after it's on paper
    ps: forgive me if it doesn't make sense
    health and peace
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,748Coins
    Hi Wallison!
    You will not have such high power consumptions with a 6DOF if you choose the right motor - ballscrew combination and correct Odrive settings. As an example: I use my Odrives with 6374 149 kv Turnigy-Motors (high recomendation for 10mm ballscrews) with 10mm ballscrews and a 2500W 24V Power suply. All 3 Odrives (6 actuators) together are powered only by this one PSU and I never had any Problem with too less power. The agresivity of the sim can be extreme if you want. But belive me- you will set some filters to make movements less fast and agressive, because otherwise a crash with a car is scary.
    Wickie
