Resolved Ouput Testing not working - Kangaroo
Discussion in 'SimTools DIY Version' started by Willem Pienaar, Sep 22, 2017.
  1. Willem Pienaar
    Willem Pienaar New Member
    488Coins
    I've just upgrade from Version 1.3 to Version 2.1 but am unable to get any response from my actuators when performing an output test.
    P.S. I am using the Dimension Engineering Kangaroo and I have used exactly the same interface settings and values in Ver 2.1 as what I've been using in Version 1.3. I have also set up a set of default axis . The actuators works absolutely fine when testing them vie DimensionEngineering Describe application.
    What seems to be suspicious is the fact that there is a little red icon between the DIY label and the Exit (X) in the top right hand corner of the Games Engine window. Is this a status indicator? - The indicator turns green if I start the Games Manager and turns blue when I turn on the Output testing.
    I have disabled my firewall (BullGuard) when I installed Simtools and whilst setting up Simtools.
    Any help/suggestions on how I can resolve this issue will be appreciated.
    Cheers
    Will
    147,878Coins
    +10,880 / 54 / -2
    The difference from SimTools 1.3 to SimTools 2.0 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it is now has designate grouping for a or b for each axis assignment, like this <Axis1a>
    In your case add an a to each axis assignment, you will not need b.
  3. Willem Pienaar
    488Coins
    Thank you noorbeast. Problem sorted.:)
  4. Vboull
    Vboull New Member
    181Coins
    Thank you for this information, I also had the same problem
  5. yobuddy
    49,199Coins
    I believe I have made this change a bit clearer in v2.2. :thumbs
    This should have been something that was included since the release of v2.
    'a' Axes
    'b' Axes
    Should help I think.
  6. Vboull
    Vboull New Member
    181Coins
    Maybe but as I just copy my old setting of the v1 without reflecting
  7. yobuddy
    49,199Coins
    Roger that, well at least it gives them a fighting chance. :grin
