Patching
Discussion in 'SimTools DIY Version' started by terry wells, Apr 8, 2014.
  1. terry wells
    terry wells Active Member
    retired military
    minnesota USA
    716Coins
    3DOF, Arduino
    When you are editing the path for LFS, what is the direction I should take? C:/LFS/DATA/ ?. where ever I go they all say "The selected Path is not Valid for Patching". I have already run the game. Also, will I be able to use this game for testing my system?
    Terry W.
  2. value1
    14,750Coins
    C:\LFS should work :)
    (The plugin is actually looking for the directory, where lfs.exe is stored in.)
  3. terry wells
    retired military
    minnesota USA
    716Coins
    3DOF, Arduino
    That Worked just fine. Was able to open the patch. Thank You
    Terry W.
  4. terry wells
    retired military
    minnesota USA
    716Coins
    3DOF, Arduino
    OK, so I downloaded the game patch DCS, dragged the zip folder into the Sim Tools Plugin update, set up the path for a connection (shows connected) started the Arduino IDE and verified and uploaded the SMC3 code, started the game, (the game manager shows that game is running) and at this point I have NO motor movement using my joystick when playing the game! I also tried to do the same thing using RacingMat_4DOF_Arduino_code. This did not work either. I would like to get this working in the one week time frame I have for the Game download. If it works I am going to become a Gold Member.
  5. SeatTime
    28,370Coins
    I don't know it this will help, but I needed to have the full game (not the demo) of LFS loaded before any data would show in Game Engine Tuning Centre (It showed 'Game Connected in the demo - but no data). It has worked perfectly since.
