PC Wheel with long Steering Column ?
Discussion in 'DIY Motion Simulator Projects' started by sci666, Nov 23, 2022.
  1. sci666
    sci666 Active Member Gold Contributor
    1,146Coins
    Hello everyone, i have a question.
    maybe some of you made it already :)
    is it possible to add a long steering column between the steering wheel and the wheelbase ? like in a real car ?
    so you save a lot of space direcly behind the wheel and you can place a gauge cluster in a real position and not above the wheel !!!! look at the MS-PAIN(T) picture :)
    ..or does it cause some problems ?
  2. Gadget999
    11,802Coins
    yes of course - works well when you have a cockpit type sim
  3. sci666
    1,146Coins
    Cool. No problems so far? What about the connections to the wheel Buttons? Diy cable?
  4. Gadget999
    11,802Coins
    Use a long coiled cable, it can rotate many times.
    Or use a small arduino board inside the wheel and use a long usb cable
  5. Harman singh
    Harman singh New Member
    120Coins
    Does this affect the power delivery of motor
  6. Gadget999
    11,802Coins
    no - unless the shaft can bend
