pneumatic Frex-like simulator design
Discussion in 'DIY Motion Simulator Projects' started by egoexpress, Dec 15, 2006.
  1. egoexpress
    you can use the x-sim software for such a project. You just have to make following settings in the Force-Profiler.
    If braking or accelerating, both axis have to move in one direction.
    If you drive through curves, g-forces have to be simulated by inverting one cylinder in the Force-Profiler
    This effect processing can be realized this way:
    Axes are named with X/Y instead of left/right, still. But that should be no problem :mrgreen:
    dieser Thread widmet sich allen Ideen zum Bau eines Simulators auf Basis eines FREX simconmotion Systems mit pneumatischen Aktuatoren und von x-sim angesteuert.
    Entfacht wurde diese Idee im englischen http://forum.rscnet.org/forum.php forum:
    Einmal von BBEL:
    Video: http://www.rogepost.com/dn/ug0m
    Webseite http://forum.rscnet.org/showthread.php?t=266543
    und von Viewtiful Job:
    Bild: http://forum.rscnet.org/attachment.php? ... 1165946988
    Webseote http://forum.rscnet.org/showthread.php?t=225439&page=11
    Ich finde das wäre ne Überlegung wert!
    Gruss
    Christian
  2. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Frex-style!!
    Already have the first drawings ready for making
    a frex-style setup!
    I'll be using my 270 mm hubs on it!
    For now i'm building new extension controller like
    http://www.cadsoftusa.com/people/kls/fl ... roller.htm .
    The extension spools are currently being made!!
    I also ordered a new valveblock (SMC SY5320-6LOZ-C6F and the rest that is needed)
    I hope it's delivered next week!
  3. egoexpress
    Hi Renoboss,
    you want to use 270mm hubs for a frex like design? don't you think thats to much hub?
  4. Renoboss
    297Coins
    2DOF, SCN5
    hubs
    Hi Egoexpress,
    270 mm is what i'm using on my chair now (doubled on a single axe) and i even ordered 2 more to replace the originals which i use in push-pull for left/right banking.
    I've have sketched up a design in which i can use them!
    Remember , by changing the angle it works on you can make shorter movements. By using the 270 mm hub i keep some margin regarding
    the weakness of pneumatics! (stopping at position X and repeating that same stop)
    As mentioned before, that's why i'm making the new extensioncontrollers! , based on a Bourns 10 turns potentiometer!
  5. egoexpress
    I'm really looking forward to see pics or drawings. Till now I can't imagine how you want to make a frex design with 270mm hub.
    regards
  6. egoexpress
    Hi Renoboss,
    any news on that?
    regards
  7. Renoboss
    297Coins
    2DOF, SCN5
    Hi egoexpress,
    No news on this new project! Have done no developing towards it at all!
    (It's very busy at work)
    First I need to figure out which profiles I need !
    Than perhaps first contact Mike78 to have him contact the Dutch Reseller!
    And to be quit onest, because of the electric actuator project my plans
    are a kind of frozen!
    CU
