Power supply - 3 - single cable
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by shannonb1, Feb 26, 2017.
  1. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    UPDATE: It works fine.
    Any issues with having a single power plug eun as the power in line to 3 power szpplies. Using a pretty thick guage wire i want to run the hot, neutral and ground wire to the first and then run from there to the next and from the second to the third. Im thinking no issues but wanted to get feed back.
  2. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    ive done it with 2 power supplies. cant see any issue atall as long as the fuse and cable can handle it
  3. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I used 12 gauge wires, worked out just fine. Keeps power even across all 3.
