power supply for jrk12v12
Discussion in 'Electronic and hardware generally' started by gigi, Dec 26, 2014.
  1. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
    HAllo to everyone!
    To feed the two boards JRK 12V12 I use two power supplies 12V 50A. Unfortunately yesterday one of the two power supply has failed andk I will be able to find a new one only next week. I would like to know if I can connect both cards jrk 12V12 to the only power I have 12V 50A? There is a risk of damaging something? I use these motors http://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html (12volt) ratio 50:1
    Thank you for your support
  2. bsft
    probably no damage, but power supply will either trip out from overload of power drain or nuke itself. JRK should be fine.
    Does the power supply have an overload cut out?
    Depends on how wild the motion profile is as to how the power supply will go.
    @Rastus , I think uses a re-wired PC psu at about 50 amps for both his bigger motors, 25:1 boxes
  3. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
    thanks bsft! I use 50:1, the power supply is broken while rbr rally was testing and in profile settings, felt roll 5, pitch5 -5, -5 and heave 5, -5
  4. Nick Moxley
    17,056Coins
    What kind of PSU's are these ?
  5. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
    sorry what does mean PSU?
  6. Nick Moxley
    17,056Coins
    Power Supply Unit
  7. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
