Question Problem installing
Discussion in 'SimTools DIY Version' started by JRG, Sep 25, 2025.
  1. JRG
    JRG New Member Gold Contributor
    30Coins
    But the problem I have is that they should turn in the opposite direction when I turn the steering wheel. In terms of response and speed, the simulator works perfectly. The only thing that is strange is turning as if you were doing it with a motorcycle.
    152,523Coins
    +11,085 / 56 / -2
    It could be that you have the Dir settings for sway misconfiguration, sway should lean away from a corner.
