Bug problem with no limits
Discussion in 'SimTools Plugins' started by cruzebabuze, Apr 26, 2016.
  1. cruzebabuze
    cruzebabuze Active Member
    135Coins
    Hi everyone, I have downloaded the no limits v2 plugin. I patched it and it does connect through game manager. but when I play game I do not get any motion at all, I check the virtual axis and I am not getting anything there at all. all other games work properly, so there is something I am not getting. the thing is usually when I patch a game it said game patched, but it does not show that when patching it???? What am I doing wrong? thank you in advance for your help:)
  2. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    My best guess is you are running NoLimits2 without the Telemetry option turned on. This one got me for a while, and the solution was pretty well hidden in the message boards:
    In order to activate the telemetry in the simulation, you must start NLS with the option --telemetry.
    Non-Steam version:
    Create a shortcut to nolimits2app.exe – right click on Properties and add to the the Target --telemetry
    Steam version:
    In your steam client library right-click on the NoLimits 2 Roller Coaster Simulation, select Properties and click on Start Options and add --telemetry
  3. cruzebabuze
    135Coins
    I think you are correct, I saw it in the log, but was not sure, thank you let me try
  4. cruzebabuze
    135Coins
    Actually I apologize, it did work on my main computer, but not on the one I was testing, thank you again
  5. cruzebabuze
    135Coins
