Problem with Pololu MICRO MAESTRO.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by matias, Nov 15, 2013.
  1. matias
    matias New Member
    3Coins
    Hi every one.
    I have a problem with my board controller, is a POLOLU MICRO MAESTRO (6 CHANNELS).
    In the X-SIM converter I don't have any problem, but with the new software I can't do that works.
    I will put an image of my configuration (in the x-sim converter) and another from the new
    configuration of SIM-TOOLS.
    In this moment I have connected 4 servos, but I don't know what configuration is the correct in the SIM-
    TOOLS software.
    I hope somebody can help me. Thanks a lot and sorry for my bad english.
  2. eaorobbie
    20,448Coins
    Ok use port settings.
    Output Bit Range should be 8.
    Startup - Output should be <255><3><0><255><2><0>..... replace ~ with <>.
    Interface - Output should be <255><3><Axis4><255><4><Axis3>....replace ~a01~ with <Axis1>.....
    For testing you need to make sure you set the default axis assignments to the same as the ones uses in the Interface Output.
    Hope that helps.
  3. matias
    matias New Member
    3Coins
    it works! you're a genius!
    Thanks a lot!
    Regards
  4. eaorobbie
    20,448Coins
    @matias, may I ask what you are doing with the servo's, is it a model?
    Glad to hear your up and running now.
