Problem with project-cars2
Discussion in 'Project Cars' started by craach-test, Jul 10, 2017.
  1. craach-test
    craach-test New Member
    paris
    141Coins
    3DOF, SCN6
    Hello
    I installed the plugin pCS2, with pluginupdaper
    But it does not appear in the list
    Neither in gme manager nor in game engine
    Je n'ai aucun problème avec d'autres plugins
    I had already posed the problem some time ago, since I completely redone my pc has nine the repert of 0 brand new : Sourire
    Thank you for your help : Sos
    I am registry pro
    148,022Coins
    +10,884 / 54 / -2
    If you reformatted your PC did you re-register SimTools2?
  3. craach-test
    paris
    141Coins
    3DOF, SCN6
    Yes
    In the appdata / local / simtools / gameplugin folder
    Does not appear
  4. born2bslow
    born2bslow Member Gold Contributor
    272Coins
    3DOF, Motion platform
    There is an option in the game to use PC1 outputs if that's any help?
  5. craach-test
    paris
    141Coins
    3DOF, SCN6
    non désolé
    Mon problème est que le plugin pcars 2 n'est pas pris en compte avec les simtools 2
    Il n'apparaît pas dans la liste des branchements ...
  6. value1
    14,751Coins
    Are you running the trial license of Simtools?
    Est-ce que tu as une licence trial pour Simtools? Tu dois une licence DIY ou PRO pour utiliser des autres plugins que Live for Speed!
  7. tabuRacing
    tabuRacing New Member Gold Contributor
    spain
    54Coins
    Hi guys, I have a problem with the project cars plugin 2, I post the plugin and it does not appear in the game mama nager, you know the solution, I'm with simtools 2.1 pro
  8. craach-test
    paris
    141Coins
    3DOF, SCN6
    Je suis avec une licence professionnelle :)
  9. value1
    14,751Coins
    Oops! Mea culpa!
    I've updated the plugin here
  10. tabuRacing
    spain
    54Coins
    Quiet man things that happen hahaha thank you very much
  11. craach-test
    paris
    141Coins
    3DOF, SCN6
    I thank you very much:thumbs
  12. lysa elec
    lysa elec LYSA ELEC
    - 68Coins
    le plugin pour project car 2 fonctionne t'i avec le fun pack
    merci
  13. lysa elec
    lysa elec LYSA ELEC
    - 68Coins
    Hello
    Simtools no work with project cars2
    I have the message " game running" but no mouving
    Simstools 2.2 asks me to validate MMF output whom I do not find
    Thank you
  14. lawmankyo
    lawmankyo New Member
    121Coins
    Does not appear
  15. noorbeast
    148,022Coins
    +10,884 / 54 / -2
    See the in-game configuration that is needed: https://www.xsimulator.net/community/faq/projectcars.188/
  16. lysa elec
    lysa elec LYSA ELEC
    - 68Coins
    i have problems with my Thrustmaster T500 RS ans sim tool 2 (bizarre eactions with accelerator ans turn)
    what happen ?
  17. noorbeast
    148,022Coins
    +10,884 / 54 / -2
    The Thrustmaster should have nothing to do with SimTools. I am guessing but suspect you may have a USB issue with your computer.
  18. lysa elec
    lysa elec LYSA ELEC
    - 68Coins
    i change of USB port of the Thrustmaster T500 but nothing else
  19. lysa elec
    lysa elec LYSA ELEC
    - 68Coins
    i have the same problem with assetto competizione
  20. lysa elec
    lysa elec LYSA ELEC
    - 68Coins
    ihave istall simtool pro jand i see the différence tomorow
