Problems offsetting output values
Discussion in 'Force-Profiler Simulator Control' started by Frakk, Dec 21, 2009.
  1. Frakk
    Frakk Active Member
    328Coins
    I'm playing around with GTR2 and trying to output some values through the USO. I am using 16bit outputs for all the axis.
    Now, my problem is that I can't offset positive only values properly, such as speed, rpm, gear, fuel level, temperatures.
    In the math setup for speed I have the Output 1:1 with 65535 max and 0 min, so I don't need to rescale the 16bit output later. The Calibration offset I pulled all the way down (-99% asymetric) so the values that are actually going out are the same numbers I am getting from the game.
    With all this, I am still getting values out that are 22 larger than my actual data, 0(input) = 22(output). If my speed in the input section is 56km/h, the USO is outputting 78km/h. If I change it to gear, I get 24 when I'm in Gear 2. I have tried other gauge data as well with the same result. In the USO settings I tried to offset the axis data where value = ( value / x * y ) + (-22), but I get no change, only if I change x and y from 1.
    I suspect If I could set the Calibration offset to -100% 0 would equal to 0, but -99% stops it.
    Can you please give me suggestions how to overcome this? Is there an other way to do this that I don't know about?
    Thanks,
    Adam
  2. Frakk
    Frakk Active Member
    328Coins
    Anyone?
  3. Frakk
    Frakk Active Member
    328Coins
    Thanks for the reply, and Merry Christmas to you!
    As I said, I tried to offset the value in the USO as you suggested but it didn't have any effect.
    Right now from what I understand the output is calculated the following way:
    Maximum value in the G-Force Math plugin will be 65536 output using 16bit from the USO, and minimum(negative maximum) will be 0.
    Now, if I have a positive only value from the game such as Speed, RPM, Fuel Level, etc. the output will range from 32768(0) to 65535(G-Force Math Plugin Maximum). If I have 400 as maximum for speed, I will have to re-scale the output because 400 will be then 65535. If I put 32767 as my maximums(65535 peak to peak), I don't have to re-scale anything because the output will be proportional to the actual values from the game.
    Now I only have to offset this value by -32768 to make 0 game data into 0 USO output. I could easily do this by:
    value = ( value / 1 * 1 ) + (-32768), but as I said it has no effect when I type it in.
    I don't want to use 32bit output because it is a real vaste of resources. I will keep playing around and post what I am finding.
    edit: I just tried 32767 as my G-force plugin maximum (65536 peaktopeak) and have no calibration offset in the math section. I am getting the speed+32767 as the output, but there is a slight %error, about 2%. So if my speed is 200, I get 32971 as the output from the USO. So far the best result I got was with my first try in my original post. G-Force plugin maximum of 65535 with a calibration offset all the way down to -99%. But no matter what, I cannot get rid of that small 22 offset in the USO, no matter what I type in I have no change. I use the latest 2.1.0.6.
  4. Frakk
    Frakk Active Member
    328Coins
    Do you have to set something for a signed integer output? I don't get 2's compliment signed binary numbers, just regular 16bit 0-65535 numbers, no sign. The only signed numbers are in the Profiler calculations.
    Of course I can do whatever scaling, offsetting and calculations with these numbers with the uC, but I would like it to be as flexible as possible and do these calculations in software for each axis. The uC can accept and process a lot of axis and I would have to set specific calculations to specific axis.. this would put limitations on the firmware if you know what I mean.
    Do you have any idea why offsetting in the USO doesn't work for me? Using the latest update.
    value = ( value / 1 * 1 ) + (any number here)
    Multiplying, dividing the number works no problems, but adding/subtracting has no effect.
  5. Frakk
    Frakk Active Member
    328Coins
    That would make sense! Adding such small numbers in a 32bit won't change anything.
    I would love to try it if my profiler started :( It freezes at the rotating circle. I had the exact same issue with 0.4. and 0.5. but not with the latest 0.6. Until now. Tried clearing registry, reinstall a couple times, but nothing. There are a couple files that remain after uninstall that can't be deleted manually. Profiler.exe, 10bitUSB.dll, AffinityModule.dll to name a few. I haven't done anything special in the last couple hours. How is it possible to fix it?
  6. Frakk
    Frakk Active Member
    328Coins
    I closed everything, uninstalled completely, deleted everything, reinstalled and I still have the same thing. Profiler is starting up forever.
  7. Frakk
    Frakk Active Member
    328Coins
    Thank you for your help! Profiler works now, subtracting bigger numbers work as well. I have to play around with G-force Maximum values and the offset in the USO because the exact 2^x numbers are not accurate. Right now I have Speed data displaying correct with 32767MAX and -2147400000 offset in the USO.
    edit: After further investigation with Speed and RPM I noticed if I use 32767 as MAX, and subtract 2147483647, I always get 1 less at the output than the actual game data. If I subtract 65535 less, -2147418112, the output is correct! I will try it with other data like temperatures, fuel level and such.
    Great Success!
